Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
mcspreader Member Since: 28 Jan 2017 Location: cornwall Posts: 56 |
I guess the Aliexpress link is specific to individuals as it works for me fine. Unfortunately their share options are limited to platforms I don't use I will look deeper but I think I just did a search for car seat cooler and the items were amongst the usual irrelevant junk the Aliexpress always spams you with. 2011c Vogue SE 4.4 Oil Burner
28th Jan 2024 3:43am |
OK, try searching for TZ032461 or for car seat refrigeration peltier in Aliexpress. If you select one you will find it then provides links to even more.The best I found for delivered price was £25 and pence although I think VAT needs to be added at final checkout. 2011c Vogue SE 4.4 Oil Burner
28th Jan 2024 4:54am |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 376 |
Hi, has anyone tried one of these Aliexpress units for real ?
28th Jan 2024 5:03pm |
Mfcetin Member Since: 26 Jun 2023 Location: Nuremberg Posts: 44 |
Yes I just replaced mine with one of these last week and works fine so far 🙂
28th Jan 2024 5:14pm |
Thanks for that. The guy who was repairing mine can't get the parts now so it's fallen through.
29th Jan 2024 9:41pm |
Griffiths Member Since: 03 Feb 2024 Location: shropshire Posts: 2 |
Hi Tinfish,
8th Feb 2024 1:41pm |
Hi, Peltier part just arraived, but the rest of the unit is still with the other "fixer", soon as I get that back I'll replace the peltier and hopefully all good.
8th Feb 2024 1:46pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1124 |
Just bit the bullet and bought the whole unit HHK500060.
13th Feb 2024 3:24pm |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 90 |
I ordered one of the alieexpress peltiers, took a couple of weeks to arrive and was about £32 all in, it seems to work , we'll just have to wait and see how long now , hopefully the OH will be happy as I only ever use the cooling but she likes the heater . |
20th Feb 2024 5:51pm |
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 62 |
Was your ducting split and did you manage to fix? I have ordered a pettier too |
20th Feb 2024 7:00pm |
Ducting was fine and still soft and pliable , had car nearly 8 years now and only just got round to sorting seat heater (not a priority for me ), i'd had it apart a few years ago to check ducting when info was less readily available and peltiers were unavailable , thought for £30 rather than a few hundred it was worth a punt , just got to see how long it lasts for now , time will tell , back heats up a lot more than base so base one could probably do with changing too but i think they are a tad more awkward to get out . |
20th Feb 2024 9:52pm |
ballast Member Since: 18 Feb 2016 Location: Midlands Posts: 31 |
just a quick update on this, AliExpress Peltier unit fitted - fairly easy swap out. Cost around £32 and works a treat!
19th Mar 2024 8:49am |
PDC Member Since: 02 Oct 2018 Location: Warwickshire Posts: 62 |
Just stripped my drivers seat down & confirmed that the peltier is not working with only about 3 ohms of resistance. I too will get one ordered this week. I just have a small crack at the base of the ducting so will fix it with a little baking soda & super glue and the job will be a gooden.... 2010 RR Autobiography 5.0 SC
20th Mar 2024 5:00pm |
