Home > Technical (L322) > Low range |
A.Pires Member Since: 02 Dec 2016 Location: Seixal Posts: 137 |
My low range system fail to connect often. I push the button o the center console and nothing happens. Sometimes when I turn the ignition on the low range light blinks o the pannel without I push the button. What can this be? |
27th Feb 2024 1:51pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1342 |
Maybe start by looking for corrosion in the wiring/connectors/control module. Only Range Rovers since 1988 |
28th Feb 2024 1:21pm |
Thank you for your answer.
28th Feb 2024 5:18pm |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 253 |
Is the vehicle in Neutral when you push the button ? Any messages on the dash ? TDV8 4.4 2012 |
28th Feb 2024 7:20pm |
Ramblin Man,
28th Feb 2024 7:42pm |
Ramblin Man
28th Feb 2024 8:00pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 912 |
Could be the switch itself, or possibly the shift motor potentiometer, which is a known weak point on the NV225.
29th Feb 2024 12:26am |
