Home > Technical (L322) > Low range
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
Low range
My low range system fail to connect often. I push the button o the center console and nothing happens. Sometimes when I turn the ignition on the low range light blinks o the pannel without I push the button. What can this be?
Post #686593 27th Feb 2024 1:51pm
CS
Maybe start by looking for corrosion in the wiring/connectors/control module. Only Range Rovers since 1988
Post #686672 28th Feb 2024 1:21pm
A.Pires
Thank you for your answer.
The control module e located behind the battery, correct?
Post #686692 28th Feb 2024 5:18pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Is the vehicle in Neutral when you push the button ? Any messages on the dash ? TDV8 4.4 2012
Post #686699 28th Feb 2024 7:20pm
A.Pires
Ramblin Man,
Yes, no messages on dashboard
Post #686702 28th Feb 2024 7:42pm
A.Pires
Ramblin Man
Yes is in neutral. No messages on the dashboard
Post #686707 28th Feb 2024 8:00pm
RRPhil
Could be the switch itself, or possibly the shift motor potentiometer, which is a known weak point on the NV225.
Phil
Post #686736 29th Feb 2024 12:26am
