Home > Maintenance & Mods (L322) > 2010 Supercharged Wheel Nuts
redshovel
United Kingdom 2010 Range Rover Autobiography Black TDV8 Barolo Black
Just got some 2010 Supercharged Wheels fitted to a n 2005 (06 Model Type)
I am sure they have the correct wheel nuts fitted but they seem to stick out a lot!
Is this normal?? ......hard to tell from looking at anything from google images etc.
Uploaded with ImageShack.us[/img]
Post #83946 26th Sep 2011 6:31pm
Centre Caps?
Post #83948 26th Sep 2011 6:32pm
Doesn't look right to me! They're sticking out way too far! Got - 2017 SDV8 Autobiography in Loire Blue
Post #83949 26th Sep 2011 6:33pm
i know they have 'range rover ' on them but are they proper landrover wheels? or replicas.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #83951 26th Sep 2011 6:34pm
The hub location does not look right to me. Take it off and reposition making sure you do each nut loose at first then do up nuts that are opposite each other....
Post #83955 26th Sep 2011 6:37pm
verydisco
Redshovel, as odd as it seems the nuts actually stick out, check on newer Rangie...
Now, before you tight them all, take them off, remove the shinny new wheels and please, take care of these ugly discs and calipers? Somthing has to be done here ! Shocked
Post #83959 26th Sep 2011 6:58pm
redshovel
Ok....I have the centre caps....just not fitted them yet.
They are Genuine Wheels purchased from a source recommend here.
Would each hub location be out of position?
So is the room undecided if this is normal or not!
Post #83960 26th Sep 2011 7:07pm
I remain unconvinced this is normal! Got - 2017 SDV8 Autobiography in Loire Blue
Post #83961 26th Sep 2011 7:11pm
we need to search for pics me thinks... Very Happy ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #83962 26th Sep 2011 7:17pm
redshovel
This is the only pic I can find of the same type of wheel, taken at an angle.
they look like they stick out here too somewhat!
http://gtcarlot.com/data/Land+Rover/Range+...68705.html
Post #83964 26th Sep 2011 7:21pm
I have the same wheels and rest assured the wheel nuts do stick out a wee bit , and unfortunately my callipers are as manky as yours redshovel Big Cry 2008 MY Supercharged
Post #83969 26th Sep 2011 7:32pm
simon1233
Here are some pictures of my wheels, the nuts do seem to 'stand proud' but I am putting this down to the relatively small 'offset value' of 8J for the 19 inch wheels. Simply put there isn't enough alloy sticking out to surround the nuts.
These are the same nuts on my 20 inch wheels where the offset is 8.5J, so there is a greater depth of material in the hub area.
If you zoom into the wheels on the LR experience vehicle you can see that the nuts are quite proud on this wheel also.
Post #83971 26th Sep 2011 7:34pm
redshovel
When u say 'stick out a wee bit', do you mean the same distance as mine?
If so guess thats just the way they will have to be.
Thanks for posting the other pics people.....can see the nuts sticking out....just the wheels I have seem to make them look to extrude even more so!
Post #83976 26th Sep 2011 7:40pm
just looked the 23mm shank nuts on ebay and some look like the 'nut' bit is more shallower than the others ....maybe there are two types of nuts.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #83978 26th Sep 2011 7:44pm
simon1233
Was wondering the same thing Stan.
I did wonder if the nut for the RRS wheels was lower in profile as when you look at the picture of my old RRS the nuts appear to be roughly flush with the alloy level on the hub. The offset on this style of alloy was 9J IIRC but the section by the hub was relatively flat...
Post #83980 26th Sep 2011 7:53pm
