Home > Maintenance & Mods (L322) > 2010 Supercharged Wheel Nuts |
redshovel Member Since: 12 Jun 2010 Location: Belfast Posts: 244 |
Just got some 2010 Supercharged Wheels fitted to a n 2005 (06 Model Type)
26th Sep 2011 6:31pm |
Centre Caps? |
26th Sep 2011 6:32pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34949 |
i know they have 'range rover ' on them but are they proper landrover wheels? or replicas.. ... - .- -.
26th Sep 2011 6:34pm |
The hub location does not look right to me. Take it off and reposition making sure you do each nut loose at first then do up nuts that are opposite each other.... |
26th Sep 2011 6:37pm |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Redshovel, as odd as it seems the nuts actually stick out, check on newer Rangie...
26th Sep 2011 6:58pm |
Ok....I have the centre caps....just not fitted them yet.
26th Sep 2011 7:07pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
I remain unconvinced this is normal! Got - 2017 SDV8 Autobiography in Loire Blue
26th Sep 2011 7:11pm |
we need to search for pics me thinks... ... - .- -.
26th Sep 2011 7:17pm |
This is the only pic I can find of the same type of wheel, taken at an angle.
26th Sep 2011 7:21pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
I have the same wheels and rest assured the wheel nuts do stick out a wee bit , and unfortunately my callipers are as manky as yours redshovel 2008 MY Supercharged
26th Sep 2011 7:32pm |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 |
Here are some pictures of my wheels, the nuts do seem to 'stand proud' but I am putting this down to the relatively small 'offset value' of 8J for the 19 inch wheels. Simply put there isn't enough alloy sticking out to surround the nuts.
26th Sep 2011 7:34pm |
When u say 'stick out a wee bit', do you mean the same distance as mine? If so guess thats just the way they will have to be. Thanks for posting the other pics people.....can see the nuts sticking out....just the wheels I have seem to make them look to extrude even more so! |
26th Sep 2011 7:40pm |
just looked the 23mm shank nuts on ebay and some look like the 'nut' bit is more shallower than the others ....maybe there are two types of nuts.. ... - .- -.
26th Sep 2011 7:44pm |
Was wondering the same thing Stan. I did wonder if the nut for the RRS wheels was lower in profile as when you look at the picture of my old RRS the nuts appear to be roughly flush with the alloy level on the hub. The offset on this style of alloy was 9J IIRC but the section by the hub was relatively flat... |
26th Sep 2011 7:53pm |
