Home > Maintenance & Mods (L322) > SUNROOF CLOSING
Brummy
Australia 2002 Range Rover HSE Td6 Java Black
SUNROOF CLOSING
The sunroof on my l322 td-6 2002 will not close.I closed the two front windows at the same time as closing the sunroof and now it wont close......Getting worried as i have to leave in Sydney airport for a week while i come up to London.
It goes to the close position then immediatly returns to the open position,anyone have any ideas ?
Post #97792 15th Dec 2011 5:56am
sidmini
United Kingdom 2002 Range Rover Vogue 4.4 V8 Atacama Sand
You might have something stuck in the sunroof channel and the range rover thinks that. You might need reset the sunroof do a search on here. Think you have to hold the sunroof button for a certain amount of time.
Post #97794 15th Dec 2011 8:42am
found using the search function.........
http://www.fullfatrr.com/forum/topic4017.html?highlight=sunroof
http://www.fullfatrr.com/forum/topic4999.html?highlight=sunroof
http://www.fullfatrr.com/forum/topic1539.html?highlight=sunroof ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #97796 15th Dec 2011 9:18am
If you keep your finger/pressure on the button when closing it should close OK. It may be something on the rails that is stopping it auto closing. Very common. Thumbs Up
Post #97797 15th Dec 2011 9:35am
I've had this and there didn't seem to be one cure for it other than keep trying, try closing it without the one touch feature, by holding it forward.
I also found that if when its re-opened itself, press the sunroof button to tilt it. THEN press the full close and it should work- that's what worked mostly for me when it has happened. Discovery 4 HSE
Post #97814 15th Dec 2011 10:58am
Lack of lubrication
Post #97818 15th Dec 2011 11:12am
Where is it lacking and what type?
Moly grease? Discovery 4 HSE
Post #97823 15th Dec 2011 11:27am
Moly grease would be too messy, a squirt of silicone spray on the runners should work Thumbs Up
Post #97824 15th Dec 2011 11:38am
Brummy
Thanks everone for your suggestions.Its night time here now, and have now got it closed by using the tilt button,then the close button.
It still does the open and close thing with the one touch button so i would assume that there is sand in the runners. Tomorrow I will clean and spray some silicone in as suggested.
Post #97826 15th Dec 2011 11:55am
The runners can also get slightly bent and no manner of spray grease or silicone will get the auto close to work. You may have to get used to manual finger closing Very Happy
Post #97829 15th Dec 2011 12:17pm
