Home > Maintenance & Mods (L322) > Sticking caliper? Fix or replace? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6349 |
Dealer price per calliper is £345.50 each! Discovery 4 HSE
7th Jan 2015 2:10pm |
Wonder how much a rebuild kit is from Brakes Int... Cant be more than £30 a side surely! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
7th Jan 2015 2:27pm |
Yep, according to AF they are anyway. Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
7th Jan 2015 4:57pm |
IS it different to the ones on the TDV8 then? or is it just a TRW like the rest...... If so they are available from most local motor factors, I got a refurbed trw one for mine from ECP and another from a local factors after the ECP one stuck on again...... the second was refurbed by brake engineering. Still about £60ish.
7th Jan 2015 5:43pm |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
Are you sure it's not a badly adjusted handbrake after refitting the new discs and pads ? I'd be amazed if the calipers on your 5.0 Supercharged were fooked already.... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
7th Jan 2015 7:55pm |
I've just spent an hour reading and searching old threads. Lost count of the numbers of people who have had the exact same symptoms, and all turned out to be callipers sticking.
7th Jan 2015 9:56pm |
When the other one went on the ff I have the heat was all the time. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
7th Jan 2015 10:11pm |
4.4 TDV8 & 5.0 use 6 pot Brembo's up front and a much larger rear calliper than was on the older 3.6 TDV8 or 4.2 |
7th Jan 2015 11:00pm |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Is it 6 pot caliper front, 4 pot caliper rear... For the 4.4TDV8 & 5.0? |
7th Jan 2015 11:20pm |
6 pot front, sliding rear.... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
8th Jan 2015 11:06am |
But is the piston at the rear bigger?
8th Jan 2015 11:27am |
No they are still the same system Will, just bigger! Almost twice the disc/pad area of my old 3,6... |
8th Jan 2015 11:40am |
So much for progress FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
8th Jan 2015 12:13pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
If they were fine before the new pads were fitted, could that not be the problem? Could the pad be sticking in the calliper in some way? I've had pads rusting in to the slides they sit in, a quick filing and lubing does the trick, but you have new pads so maybe not. Previously..
8th Jan 2015 12:29pm |
