Home > Technical (L322) > "rear water ingress"
Page 9 of 11 <123 ... 8 91011>
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
JustinP wrote:
I've removed the bumper and tow bar aperture and there's no sign or any water staining around the gaskets or in the sleeved holes Sad
I'm going to pop out and get something to replace the gaskets as they are now in bits and then will then be able to put the car back together. I'm hoping that Halfords or B&Q will have something suitable.
It's a shame that this was not the source of the leak, but at least I've ruled it out.
Once back together I will remove the boot seal.
Justin, it wasnt obvious from looking at the armature gaskets on mine that there was a leak through them but it was most definitely leaking from there.........don't rule it out Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #100735 8th Jan 2012 12:03am
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
I fitted new gaskets made from Evo Stick Flashband, which is a lead free self-adisive flashing strip
I was looking for something that would compress under pressure, and this stuff actually squashed out the edges when I tightened up the bumper mounting nuts to pull the bumper towards the car. I also used some black guttering joiner around the top and sides of the armature and around the tow bar electrics grommet and the rear PCD sensor grommet just in case.
Here's a couple of photos with the bumper off showing the tow bar armature before I refitted with new gaskets
and here's one with the tow bar armature removed,
The rectangle hole opens up into structural box section. Both the inside of the box section and the 8 sleeve holes were clean and bone dry and showed no signs of any water having been in there.
There's a chance it was leaking from the bumper mounting holes, but I'm not confident so I will test the boot seal using a hosepipe tomorrow.
Gone - Range Rover Supercharged 2006
Post #100743 8th Jan 2012 12:49am
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
Justin,
just a quick tip, about the hose pipe thing, you will need to pour it for a while id probably say about 15-20 mins before you might see anything, i suspect most leaks take time for them to start but when the do and have a channel of water going it doesnt stop. i would say it might be a good idea to go out in the rain one day...
i know its not the best but it works, i went out in the rain and thats how i seen the leak, i sat there and looked for it with a very good torch looking deep inside where the bolts are etc etc
good luck Thumbs Up
Post #100744 8th Jan 2012 1:01am
CG-SC
Good job Justin Thumbs Up at least you can rule that out now......fingers crossed for you....I know how it feels to have water ingress Twisted Evil Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #100752 8th Jan 2012 9:09am
When I tested the door seal with a hose pipe the leak was evident almost instantaneously. By removing the hose and re-applying I could stop and start the leak at will. Top left corner.
Post #100757 8th Jan 2012 10:19am
Diver Bryn
United Kingdom 2005 Range Rover Vogue Td6 Tonga Green
Knips wrote:
I'm getting a bit jumpy over these rear water ingress problems as there doesn't seem to be a single cause.
I've started sticking my hand down the side of the spare and as far down as I can reach beside the TV tuner every time I use the vehicle to check for dampness. I think I am going to buy a battery powered Velleman water alarm next weekend!
Hi, I am new to this site. I have a 2005 model year L22 Range rover Vogue TDV6 / purchased from new, that now has 105,000 miles on clock. Fabulous condition but in last two months, has heavy condensation inside vehicle. I have already had this condensation problem before, inside the rear left panel that, required new sat nav connectors through H2O corrosion. Took out spare wheel over weekend and there was a quarter litre of clean water in spare wheel well, with moisture covering the top of the spare wheel and also inside rear left and right panels - Holding all the vulnerable electric’s! Car is used once a week. I have heard that as I use the air con, all the time this in turn builds up moisture? Is there not a vent built in to prevent this moisture collecting inside the vehicle? Have followed the links bumper bolts tight and sealed, have had problems with rear wash motor where pipe disconnected, although at that time no moisture was located in well bay even after pressing washer?? Any Solutions out there greatly appreciated. Can confirm that No liquids have been spilt inside, as a preventative temporary clean up, I have placed in spare tyre well 4 x boxes of sorbsill moisture absorber to take out this condensation until a full fix is found. Interesting to see that I am not the only one facing this problem. Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Renault Fuego 2 ltr TX
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Volvo 740 TDi Estate
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Land Rover Discovery 3 TDV6
Mini Cooper Diesel
Mercedes Vito Van 111
Range Rover TD6
VW Golf 2ltr GTD 2015 Year
2016 Audi Q7 Sline 3ltr 272Bhp
Post #101945 16th Jan 2012 4:08pm
Diver Bryn
Possible cause to the condensation is the air compressor situated under the rear spare tyre (Mine has been making some disturbing noise's over the past few months) coupled with about 1/4 litre of condensation pooled below it. I am looking at this option this weekend. Regarding the sat navs that were ruined in the rear right quarter panel from previous post's due to water ingress. Mine had the same problem where the power pin correded and broke off. My good electronics friend disassembled the male ten pin connector block and rebuilt the unit, it is now good as new. The L/R dealer wanter in excess of £1,500.00p to replace it!!!
A couple of beers and job jobbed. Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Mini Cooper Diesel
Range Rover TD6
Post #102509 19th Jan 2012 9:53pm
JustinP
Is rained for the first time since I replaced the tiow bar armature gaskets, and as suspected my spare wheel well is wet again.
It still looks to be coming in under the rear seam, so I'm going to have a closer look at the boot seal next.
Post #102512 19th Jan 2012 10:17pm
Renegade2
I have been following this post with some interest as i too suffer from the same problem. I have applied the obligary vaseline around the armature gasket area and still have water ingress somewhere into the rear bootwell. I had the same problem on my old P38.
I dont seem to have it coming in on the left or right although did at one stage have in on the righthand pillar trim stopping where the speaker is, but that seems to have gone away, but i am sure will be back. I can not beleive that what cost me £63k new is worse than my wifes renualt which was only £16K. Most exspensive seive i have ever bought, and the wife is always reminding me!
I can belive that here we all are, with collectivly hundreds of thousands of ££££ worth of Prestige motors and landRover do not seem to give a T^&*.
Infact looking at the whole site what brand new is eqivalent in cost for 4 houses up the wesh valleys that dont have water ingress you would think that LR would get involved and solve more of the problems for past, current and new customers, come LR it is a joke now.
That said having owned this is my 4th FFRR i dont think i could drive anything else but i am sure we could all do with the hassle.
Sorry guys rant over, just kicked the cat!
Post #102525 19th Jan 2012 11:39pm
Diver Bryn
Your 100% Correct when it comes to Land Rover using us as the guinea Pigs to fault find there design flaws. I had one of the first 2005 model year touch screen Vogues that was blighted with electronic Gremlin's in the end the dealer was legally forced to take it back and swap out for a new on. Ironically what other vehicle is out there that even compares. Perhaps land rover will add another fitted extra as standard to the Rangee........A bilge pump! Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Mini Cooper Diesel
Range Rover TD6
Post #102637 20th Jan 2012 4:19pm
JustinP
I went out to further investigate my leaking boot and my spare wheel well has collected over 5mm of water over the last couple of days Big Cry
The good news is that I'm 99% certain thats I've identified the cause, and as others suggested it is indeed the boot seal.
With me sat in the boot, and the wife outside with the hosepipe, the water eventually started to make its way into car.
I removed the boot seal and discovered a small split on the top left courner.
I will order a new seal on Monday, so hopefully I will be dry again soon.
Cheers for the advice chaps Thumbs Up
Post #102805 21st Jan 2012 1:36pm
RR8701
Thumbs Up Good Job justin (I work with alot of the guys in the USA at work Razz)
I have to say very poor performance from LR, I have noticed most of the people who have boot seal issues are roughly of the same period. LR should really have this as part of the service plan, generally cheap item but major pain in the ass.
I have had cars that were 15 yo, 10 yo, rovers, fords, pugs, merc. never had such as issue.
Post #102810 21st Jan 2012 2:04pm
Diver Bryn
Whilst painstakingly trying to resolve this leak. Your 100% correct guys water is definately coming in from near side rear panel in corner. Rain water is seeping in and when washing car pouring in. hopefully now fixed with foam Gasket and as a precaution new tail gate boot seal. :thumbsup: Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Mini Cooper Diesel
Range Rover TD6
Post #104066 28th Jan 2012 11:12am
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
just a quick question how much is a new boot seal Thumbs Up
Post #129917 8th Jul 2012 1:43pm
JustinP
I can't remember, check with Dan from Duckworths Thumbs Up
Post #129919 8th Jul 2012 1:48pm
