Home > Technical (L322) > Quick question about diagnostic tools and service reset
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
Am I right in thinking of all the commonly available OBDII diagnostic tools only the more expensive faultmate (msv-2) can reset the service indicator on an L322?
Unfortunately the manual reset via the left reset button on the dash doesnt work on my touchscreen 2005TD6.
Cheers
Post #102500 19th Jan 2012 9:29pm
Reformed
Have you tried the slightly different varients of the sequence.
http://www.fullfatrr.com/forum/topic147.html
I had to try a few times before mine worked when mine was serviced. Reformed
Post #102501 19th Jan 2012 9:37pm
tomthevet
Yes tried as many methods as I can find, door open, door closed, screen on home screen, screen on other screen, even tried right hand reset button in all combinations as well with no joy sadly as car is now freshly serviced by my own fair hand.
Cheers
T
Post #102510 19th Jan 2012 9:58pm
tomthevet
Anyone know about service reset tools for touchscreen model?
What about Faultmate FCR or Hawkeye?
Or has anyone used an All comms on a touch screen model?
T
Post #102829 21st Jan 2012 3:42pm
tomthevet
Mm well I have done my own research on Hawkeye as I dont fancy the Allcomms as it wont do Td6 engine yet and may have problems with an 06 VIN, equally the Faultmate FCR doesnt have a service rset function as far as I am aware.
So, question is has anyone got an IIDtool and if so does this allow reset service?
If it does then this seems better than the Hawkeye.
Finally though can either be used on both an L322 Td6 and a Disco Td5???? Or is the hardware totally different?
Cheers
Post #102962 22nd Jan 2012 4:40pm
RRPhil
I wouldn’t get too excited about the Faultmate MSV-2’s capabilities with regard to resetting the service indicator (at least on ‘02-‘05 models) or you’ll be very disappointed. You work through the menus as usual to get to the Instrumentation Pack settings and then, encouragingly, a button appears to reset the indicator :
Click on the button and, guess what, it simply puts up a page showing the usual manual instructions Crying or Very sad :
Maybe not what you might expect for £1000? I don’t know what the system is with ’06-onward vehicles.
Phil
Post #102977 22nd Jan 2012 6:34pm
tomthevet
OK another one bites the dust it seems!
Hawkeye looking more likely unless the IIdtool is worth the extra???
Post #103000 22nd Jan 2012 7:27pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
I think bell auto services do a dedicated service reset tool that plugs into the obd for around £70 or summink like that if it helps onto no6 Range Rover
Everyone needs a hobby
Post #103002 22nd Jan 2012 7:36pm
piecost76
You are very welcome to drive down to Kent & use my Hawkeye - may cost you a bit in fuel mind Whistle Quis custodiet ipsos custodes?
15 MY 110 XS USW
54 FFRR Vogue TD6 Touchscreen - Gone!
56 FFRR TDV8 VSE - Gone!
Post #103003 22nd Jan 2012 7:39pm
tomthevet
Ah a Hawkeye user!
So is it a good buy? It presumably has the service reset? And can you answer whether the same device can be used on a TD5 with a license purchase or something?
T
Post #103005 22nd Jan 2012 7:53pm
piecost76
Yes the Hawkeye can be used for service reset!
As to multi vehicles, the good thing about the Hawkeye vs let's say a Faultmate is that it can be used for any vehicle type (e.g. L322) and is NOT locked to a particular chassis number.
Personally, I have the ability to diagnose both L322 & also Disco 3 vehicles.
If you wanted for example to have access to both FFRR & a Disco Td5 then you would need to purchase an additional unlock code (approx £170)
Here's the brochure:
http://www.bearmach.com/downloads/Diagnost...ages_d.pdf
And the user manual:
http://www.bearmach.com/downloads/Diagnostic/User%20Manual.pdf
Example pricing is here but do a Google search as many people supply them, not just Bearmach!
http://www.paddockspares.com/land-rover-to...stics.html
One thing that a Hawkeye can't do however is program the vehicle CCF file so you are not able to "personalise" it or add new keys for example. For that you would need a Faultmate. It does diagnose & reset both the FBH & EPB mind!
If you want to know more, then just give me a PM Thumbs Up Quis custodiet ipsos custodes?
15 MY 110 XS USW
Post #103089 23rd Jan 2012 9:59am
