![]() | Home > Technical (L322) > Quick question about diagnostic tools and service reset |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
Have you tried the slightly different varients of the sequence.
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 ![]() ![]() ![]() |
Yes tried as many methods as I can find, door open, door closed, screen on home screen, screen on other screen, even tried right hand reset button in all combinations as well with no joy sadly as car is now freshly serviced by my own fair hand.
Anyone know about service reset tools for touchscreen model?
Mm well I have done my own research on Hawkeye as I dont fancy the Allcomms as it wont do Td6 engine yet and may have problems with an 06 VIN, equally the Faultmate FCR doesnt have a service rset function as far as I am aware.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1023 ![]() ![]() |
I wouldn’t get too excited about the Faultmate MSV-2’s capabilities with regard to resetting the service indicator (at least on ‘02-‘05 models) or you’ll be very disappointed. You work through the menus as usual to get to the Instrumentation Pack settings and then, encouragingly, a button appears to reset the indicator :
OK another one bites the dust it seems!
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
I think bell auto services do a dedicated service reset tool that plugs into the obd for around £70 or summink like that if it helps onto no6 Range Rover
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 ![]() ![]() |
You are very welcome to drive down to Kent & use my Hawkeye - may cost you a bit in fuel mind |
Ah a Hawkeye user!
Yes the Hawkeye can be used for service reset!
