Home > In Car Electronics (L322) > ULF Bluetooth rewire doesn't work
mjdronfield
Hi folks,
As the title suggests, I obtained a new 54 pin connector this morning, and rewired the connector using a chart kindly supplied by Ajay(UK) - Many thanks.
I did the rewire by moving the 14 required connections to the new plug and then plugging the new plug into the ULF. So all the "isolate in another connector" or "not used" wires (according to the charts), are not there at all.
I can't get Telephone to show on the Nav screen.
I double checked the wiring against another chart I got from the L322.com site, and there were some differences ;
Pin 2 to 11 instead of 38 to 11
Pin 19 to 32 instead of 2 to 32
Pin 24 to 36 instead of 34 to 36
I made the above changes, and I still don't see "Telephone".
I have tried 2 ULF's...........
Does the option appear straight away ?
I would say that I think I've wired it correctly, but obviously I haven't.
I've have attached the antenna, if that changes things.
A bit stumped now.
Mk4 nav if that helps.............
Any ideas ?
Thanks
Mark (in a very snowy Chesterfield) 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #105480 4th Feb 2012 10:00pm
daveo
trying to find my old chart but i think that you need to remove the unused wires from the plug.. V8 facelift Range Rover Autobiography 22" wheels.
Post #105498 5th Feb 2012 12:29am
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Your first two pin changes only relate to the eject box for the centre arm rest and it maybe that the other wiring diagram used different wiring at the eject box end - it only uses three wires at this end none of which effect the unit firing up. Confused
The only pins needed to get the ULF working are the two positive ones, a ground and the ibus, these are pins 15, 17 35 & 36 - all the others relate to microphone, audio mute, speaker, voice or eject box and will only effect their corresponding function. For example if the mic wires are not connected then you can shout as much as you like but it wont hear you Wink
Assuming the connections are correct the telephone option should appear on the monitor without any reprogramming Confused
This may seem daft but have you checked to make sure your phone loom is actually connected to the main loom? This is the white 12pin x400 plug often tucked wayyyyyyyy down under all the other modules: Details here:
http://www.fullfatrr.com/gallery/albums/us...wiring.pdf
The only other things I can suggest are general "house keeping" making sure the relevant fuses haven't blown and perhaps trying a voltage meter Question
I have done this twice so I know it works Thumbs Up
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #105499 5th Feb 2012 12:38am
mjdronfield
Many thanks gents.
That'll be Fuse 22 in the Passenger Compartment blown then.
That could have been blown for years........who knows.
Fuse replaced and Telephone has appeared on the display.
Will fabricate a pairing button using pins 32 and 36, and I should then be able to test the microphone etc later......
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #105528 5th Feb 2012 11:12am
Ajay(UK)
Thumbs Up Sometimes it's the simple things that test us in the end Wink
Post #105600 5th Feb 2012 5:19pm
