Home > Technical (L322) > CTEK hard wire kits
Page 1 of 4 1234>
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
CTEK hard wire kits
Am having trhe usual battery drain issues with my TD6, and until I can find it and rectify it I wil leave the FFRR on charge while I'm not using it, I got the Lidl intelligent charger very similar to the CTEK range. Ive seen the hard wire kits for CTEK that allow you to simply plug the charger into a socket under the bonnet/front grill and unplug when finished. Could the hard wire kit be modified to fit my charger? Or could I make something similar up with some cable and a waterproof plug/socket for under the bonnet?
Any help greatly appreciated
Post #105956 7th Feb 2012 6:52pm
Are you charging the car in a garage or outside?
Post #105982 7th Feb 2012 8:03pm
What connection is on the lead of the charger you have?
Post #105989 7th Feb 2012 8:21pm
mrblonde
Charging outside gents
The charger I've got an the moment has small versions of the usual clamp/crocodile clamp type of connection, could I clamp these onto each wire that goes into the other part of a waterproof plug/socket?
Post #106022 7th Feb 2012 10:10pm
What I've got is a mains cable, 5A lighting 2 core circular cable fed from an outside water-proof socket on the garage wall, with a 13A rubber socket fed into the car thro a door opening at the bottom and the door closed on it. In the car, charger plugged into the rubber socket, and then the charger plugged into the front cig socket. Mines a ctek but you could buy this
cut the adaptor plug off the end and then connect to the leads on your charger.
Or make-up your own.
Works very well for me.
The lead shown is a Ctek accessory, about £8.
Post #106027 7th Feb 2012 10:18pm
mrblonde
cheers nicedayforit
That was my plan, CTEK cig lighter lead liek the one you shown, cut the end off and attach to my charger, maybe some nice ends on that lead for my mini-crocodile clips from my charger to bite onto. Was worried about thickness of cable used, load rating etc or am i worrying over nothing? (I'm worse that useless with electrics I'm afraid)
Also, will it make a difference if the car is 20m away from the house and using an extension lead, or 40m away and using 2 x 20m leads? Embarassed
Post #106130 8th Feb 2012 5:58pm
I'm assuming like me you are going to put the charger in the car out of the weather and run a mains cable extension lead to the car.
I that case 5A lighting cable will be fine for the extension lead whether it's 20 or 40m away.
There is only a very small current in the mains cable so the voltdrop will be negligible.
I trust no-one will interfere with the mains cable.
I should advise that as you are running a mains cable to your car outside you should plug the cable into a socket protected by a RCD rated at no more than 30mA for safety reasons. If no such protected socket is available you should invest in a RCD adapter to use in the socket prior to plugging the extension leads into it.
You would of couse be better in the longer term to arrange to have installed a protected waterproof mains socket outlet nearer to where you park your car so that you can do away with the need for such a long extension lead.
Post #106134 8th Feb 2012 6:22pm
SparkyPhil
England 2005 Range Rover Vogue 4.4 V8 Adriatic Blue
I dont want to to tread on anybodies toes, but if you are making you own extension cable/lead I would really recommend that you use 3 core flex with a csa of 1.5mm squared, so the extension cable/lead may and can be used safetly on other eletrical items when necessary. I know this sounds a bit over the top for a small battery charger but if someone else uses it for some other electrical item it could end in tears. If you need any advice/info on anything electrical pm me and will be happy to help
All the best
Phil
Post #106141 8th Feb 2012 7:49pm
I would agree with you the only trouble is the mains cable needs to pass thro the door seals to use as described.
3 core, 1.5mm is just a bit too big a diameter to do this successfully without affecting the seals.
Nobody touches my dedicated extension cable or else. Laughing
Post #106144 8th Feb 2012 7:54pm
SparkyPhil
This I totally agree with but I have had the what if's beaten into me over the years, so I now air on the side of caution all the time.
All the best
Phil
Post #106149 8th Feb 2012 8:17pm
Why not keep the charger inside the building and extend the 12v side of it Whistle
Makes for a safer solution all round Thumbs Up
Post #106152 8th Feb 2012 8:26pm
I tried that initially but the charger kept going to "error". Don't know why but as soon as I went to option B no problems.
Works for me ok.
Post #106153 8th Feb 2012 8:30pm
SparkyPhil
Bow down
Post #106154 8th Feb 2012 8:31pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Volt Drop? Whistle
Post #106157 8th Feb 2012 8:52pm
SparkyPhil
Just been thinking about the volt drop.
so the cable may have to be bigger than you think
Phil
ps I am not going to the van to get my regs book and work out what size is required
Post #106160 8th Feb 2012 9:03pm
Page 1 of 4 1234>
