![]() | Home > Technical (L322) > CTEK hard wire kits |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2073 ![]() ![]() ![]() |
I would say thicker than the connector being 12v |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
What happens when the battery is down a bit and you are pulling 6A on the dc side? |
SparkyPhil Member Since: 29 Oct 2011 Location: Staffs Posts: 59 ![]() ![]() ![]() |
assuming all the other figures are the same then the volt drop would be 5.28v. Phil |
Therefore as the max voltage output of the charger and most chargers is 14.4V the supplied voltage to the battery would be 9.12V.
to pull 6amp on a 12v system over 20 metres you would need a csa of 16mm squared |
Is the 40m distance within your own property? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3940 ![]() ![]() ![]() |
Cut the clips off leaving sufficient length and buy some 4mm "banana" inline plugs and sockets to fit and do the same with the ctek accessories or fit sockets on the charger.
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Gents
Gents
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
I have wired one into my car with a cheap lawnmower type plug on the mains power under the bonnet in a dry area, when i want to charge the car or leave for a prolonged period i just connect the mains from my old mover lead with RCD plug under my bonnet and walk away... Simples...
All
How exactly have you connected the Ctek to the battery?
CTEK is the indicator light thingy, and a charging adapter on the end of it, its connected to the car battery itself with eyelets to the terminals, and coiled up in the battery compartment (theres about 10 inches of cable) |
would it make a difference where it is nicedayforit? Just wondering as I'm useless with anything electrical |
