![]() | Home > Maintenance & Mods (L322) > Jacking the FF |
W88DY M Member Since: 15 Sep 2011 Location: liverpool Posts: 116 ![]() ![]() ![]() |
Hello all
Sorry when you say unspung wher about
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6432 ![]() ![]() |
EDITED read later posts NOT RECOMMENDED
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
RAVE explicitly states not to jack under the wishbones.
You need to lock the Suspension in "Off Road" height by leaving the tailgate open.
Here's what RAVE says:
That's a fair comment and I withdraw my post. The Suspension arms are quite delicate but properly protected with soft flat wood it is the quickest way to jack but as you say NOT RECOMMENDED as you may well damage your car. |
I'm with you Gaz. Always jacked on the lower suspension arms using a proper trolley jack with a soft pad. Never damaged a car yet.
I was only posting from experience probably jacked 40 Range Rovers this way over the years never damaged one in any way but its NOT RECOMMENDED - don't do it. |
Muddywheels Member Since: 18 Jun 2012 Location: East Riding of Yorkshire Posts: 394 ![]() ![]() |
My 2010 RRS was being serviced last week by a well known Nationwide LR dealer when it slipped off the lift while the wheels were removed. They have lent me a TDV8 Vogue while they assess the damage and I am seriously tempted |
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 ![]() ![]() ![]() |
When I lifted my FFRR, I used a High Lift 3 tonne jack on the usual jacking points just under the door sills....
I must be the only one here who has never had a problem with the standard jack on all my vehicles, I just follow the instructions in the handbook and all is well (that's for either a one off blowout - or swapping all four wheels for my MT/R's) Land Rover Addict
I have swapped summer/winter wheels since I got my RRS without incident following handbook - used off road height setting and scissor jack provided under jacking points - never had a problem |
It is in Rave Up front on the subframe just behind the lower wishbone, at the back, again on the subframe, forward of the suspension, or you can use the towbar bracket to take the weight. I tend to use a combination of jack and axle stands for safety, and often shove a wheel under the car too. Easiest way to jack is to set off road height, and pack out underneath the jack with stable planks, and a small block between jack and jacking point. This way you have less travel on the jack, an easier lift and a more stable lift too. Alternatively I would love to have a four post hydraulic lift, but then I would need a double height garage ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
