Home > Maintenance & Mods (L322) > Jacking the FF
W88DY M
United Kingdom 2003 Range Rover Vogue Td6 Oslo Blue
Jacking the FF
Hello all
Is there a special way to jack up my ff. The jack that came with the car
Has broken Censored
I've used bottle and trolley jacks but the suspension seems to just keep on
going.
Any info would be welcom
Thank mark Thumbs Up Thumbs Up
Post #115021 27th Mar 2012 2:13pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
Jack it under any unsprung part of the car and it'll go up fine.
You'll need a reasonably hefty trolley jack though. Just don't buy the Halfords quick-lift one which is £50-ish, it weighs a ton, and it needs massive lever pressure to raise the car despite being rated at something like 3 tonnes! I have an ancient, and frankly falling apart, little old trolley (as in, spproaching 30 years old) and it's still much better!!
Post #115023 27th Mar 2012 2:15pm
W88DY M
Sorry when you say unspung wher about
Mark Thumbs Up
Post #115026 27th Mar 2012 2:26pm
EDITED read later posts NOT RECOMMENDED
{At the rear, under the wishbones
At the front under the hub}
use lots of packing, and always support with axle stands, never just on the jack.
FWIW I use my ancient trolley jack (3 tonner) on the standard jacking points under the body, but pack out below it with a couple of short scaffold planks. I get enough lift to get a wheel off the ground. .
Post #115041 27th Mar 2012 3:35pm
ric355
RAVE explicitly states not to jack under the wishbones.
The easiest thing to do is to use a trolley jack on the jacking points, with a small block of wood between the jack pad and the jacking point.
You can optionally jack the front from the centre to lift both wheels at the same time. There's a flat point on the subframe just behind the plastic undertray. At the rear, RAVE states it is ok to jack from the centre of the towbar but I've never tried that (or fancied doing it to be honest).
Post #115055 27th Mar 2012 5:00pm
You need to lock the Suspension in "Off Road" height by leaving the tailgate open.
In this height setting the wheels will not droop when you start jacking. Thumbs Up
Last edited by Gazellio @ Prestige Cars on 27th Mar 2012 6:57pm. Edited 1 time in total
Post #115067 27th Mar 2012 6:28pm
ric355
Here's what RAVE says:
DO NOT POSITION JACKS OR AXLE STANDS
UNDER THE FOLLOWING COMPONENTS:
l Body structure other than approved jacking
points
l Bumpers
l Fuel lines
l Fuel tank
l Brake lines
l Front or rear suspension arms
l Transfer box
l Steering linkage
l Front or rear differential units
l Engine sump
l Automatic gearbox
Can't see why you would want to advise someone to do something that the official workshop manual explicitly states should not be done.
Post #115072 27th Mar 2012 6:44pm
That's a fair comment and I withdraw my post. The Suspension arms are quite delicate but properly protected with soft flat wood it is the quickest way to jack but as you say NOT RECOMMENDED as you may well damage your car.
Post #115077 27th Mar 2012 6:56pm
mzplcg
I'm with you Gaz. Always jacked on the lower suspension arms using a proper trolley jack with a soft pad. Never damaged a car yet.
RAVE has to account for idiots who might decide to use a scissor jack, you know, like the Censored thing LR supply with the car. That would definitely be a bad thing to do.
What is it about rules being for the guidance of a wise man, and the blind obedience of a fool ??
Post #115080 27th Mar 2012 7:01pm
I was only posting from experience probably jacked 40 Range Rovers this way over the years never damaged one in any way but its NOT RECOMMENDED - don't do it.
Post #115082 27th Mar 2012 7:03pm
Muddywheels
My 2010 RRS was being serviced last week by a well known Nationwide LR dealer when it slipped off the lift while the wheels were removed. They have lent me a TDV8 Vogue while they assess the damage and I am seriously tempted Shocked
My handbook states -
WARNINGS
Ensure that the air suspension is set to off-road height
- this was not the case when the dealer lifted my RRS to view underside damage with suspension set at normal height Rolling Eyes
CAUTION
Only jack the vehicle using the jacking points described, or damage to the vehicle could occur
Had these instructions been followed with the lift type below everything should have been fine Thumbs Up
The lift below was used to support suspension arms while wheels were removed resulting in metal to metal contact and my RRS sliding sideways and coming to rest on the posts Evil or Very Mad
In my opinion this lift is probably ok for leaf or spring suspension but certainly not for RRS/RR/Disco with air suspension particularly in view of clear handbook instructions and diagram Rolling Eyes
I recommend you ask your dealer how they lift your car next time it goes in Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Still hoping for a S2 one day!
Post #126653 18th Jun 2012 9:15am
Saint.v8
Location: UK< Surrey - Near the Middle Close to Some Green Bits
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
When I lifted my FFRR, I used a High Lift 3 tonne jack on the usual jacking points just under the door sills....
It took a lot of travel to lift the wheel clear, but did manage it, just!!
Next time I will be looking to pack the jacking point with a block so the jack isn't quite at full reach....
Just an associated query, where would it be best to place an Axle Stand, as I placed one on the tubular Sub Frame and when I lowered onto it, it seemed like the car was going to rock the opposite side up, i.e. use the axle stand as a pivot like a see-saw...so I lowered weight onto the stand, but kept the jack in place for stability....I was only checking the ABS sensor, so didn't have it like that for too long....
Where is the best place for stands??
Post #126660 18th Jun 2012 9:58am
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
I must be the only one here who has never had a problem with the standard jack on all my vehicles, I just follow the instructions in the handbook and all is well (that's for either a one off blowout - or swapping all four wheels for my MT/R's) Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #126662 18th Jun 2012 10:03am
Muddywheels
I have swapped summer/winter wheels since I got my RRS without incident following handbook - used off road height setting and scissor jack provided under jacking points - never had a problem Thumbs Up
I am no expert but the dealer should be Rolling Eyes Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #126664 18th Jun 2012 10:10am
It is in Rave
Up front on the subframe just behind the lower wishbone, at the back, again on the subframe, forward of the suspension, or you can use the towbar bracket to take the weight. I tend to use a combination of jack and axle stands for safety, and often shove a wheel under the car too.
Easiest way to jack is to set off road height, and pack out underneath the jack with stable planks, and a small block between jack and jacking point. This way you have less travel on the jack, an easier lift and a more stable lift too.
Alternatively I would love to have a four post hydraulic lift, but then I would need a double height garage Smile .
Post #126669 18th Jun 2012 10:51am
