Home > Maintenance & Mods (L322) > headlight washers
daveo
headlight washers
hi, has any one with a 06 face-lift conversion connected the head light washers up and did they work, had a quick look at my one's and can see where they have blank of the headlamp washer pipe on the old headlights but don't know why they did not connect the new ones back up, say that they did say it was a further 120 pounds V8 facelift Range Rover Autobiography 22" wheels.
Post #118516 20th Apr 2012 9:40pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
i did the 2004 to 2010 upgrade and have the power wash working a treat, theres two wires that need bridging on the old headlight wiper motor plug. ill have a look at the wiring diagram and let you know.
Post #118524 20th Apr 2012 10:55pm
arron
you need to join the black with yellow tracer to the black with brown tracer on the origanal headlight plug on the left headlight, power washers should work as they did when they had wipers as well.
Post #118529 20th Apr 2012 11:50pm
daveo
thanks for that, would that be left as you sit in the car or as you look at the front, did you use the same pump V8 facelift Range Rover Autobiography 22" wheels.
Post #118563 21st Apr 2012 10:04am
arron
the proper left of the car not the one as your looking at it Laughing i used a new pump from land rover as its a higher pressure than the standard one, only trouble is if you decide to buy the new pump you need the washer bottle aswel. might be worth trying the standard pump and seeing how it perfoms.
Post #118571 21st Apr 2012 10:36am
daveo
thanks for that, how does or when does yours spray, when you use the wipe wash or is it every so many wiper washes it will do the headlamp wash
thanks dave V8 facelift Range Rover Autobiography 22" wheels.
Post #118573 21st Apr 2012 10:48am
arron
it washes when you have your headlights on and the first wash of the screen then its washes something like every 4th or 5th wash of the screen there after.
Post #118592 21st Apr 2012 3:52pm
daveo
thanks Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #118605 21st Apr 2012 6:15pm
Dolphinboy
@daveo, did you ever got your washers working? any tips/pics??
Post #289206 27th Oct 2014 4:41pm
