![]() | Home > Maintenance & Mods (L322) > headlight washers |
| arron Member Since: 21 Sep 2010 Location: lincolnshire Posts: 123
i did the 2004 to 2010 upgrade and have the power wash working a treat, theres two wires that need bridging on the old headlight wiper motor plug. ill have a look at the wiring diagram and let you know. |
you need to join the black with yellow tracer to the black with brown tracer on the origanal headlight plug on the left headlight, power washers should work as they did when they had wipers as well. |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307
thanks for that, would that be left as you sit in the car or as you look at the front, did you use the same pump V8 facelift Range Rover Autobiography 22" wheels.
the proper left of the car not the one as your looking at it |
thanks for that, how does or when does yours spray, when you use the wipe wash or is it every so many wiper washes it will do the headlamp wash
it washes when you have your headlights on and the first wash of the screen then its washes something like every 4th or 5th wash of the screen there after. |
thanks |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285
@daveo, did you ever got your washers working? any tips/pics?? |
| All times are GMT |
