|  | Home > Maintenance & Mods (L322) > headlight washers |
| arron Member Since: 21 Sep 2010 Location: lincolnshire Posts: 123      | i did the 2004 to 2010 upgrade and have the power wash working a treat, theres two wires that need bridging on the old headlight wiper motor plug. ill have a look at the wiring diagram and let you know. | ||
|  20th Apr 2012 9:55pm |
| arron Member Since: 21 Sep 2010 Location: lincolnshire Posts: 123      | you need to join the black with yellow tracer to the black with brown tracer on the origanal headlight plug on the left headlight, power washers should work as they did when they had wipers as well. | ||
|  20th Apr 2012 10:50pm |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307      | thanks for that, would that be left as you sit in the car or as you look at the front, did you use the same pump V8 facelift Range Rover Autobiography 22" wheels.
|  21st Apr 2012 9:04am |
| arron Member Since: 21 Sep 2010 Location: lincolnshire Posts: 123      | the proper left of the car not the one as your looking at it  | ||
|  21st Apr 2012 9:36am |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307      | thanks for that, how does or when does yours spray, when you use the wipe wash or is it every so many wiper washes it will do the headlamp wash
|  21st Apr 2012 9:48am |
| arron Member Since: 21 Sep 2010 Location: lincolnshire Posts: 123      | it washes when you have your headlights on and the first wash of the screen then its washes something like every 4th or 5th wash of the screen there after. | ||
|  21st Apr 2012 2:52pm |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307      | thanks  | ||
|  21st Apr 2012 5:15pm |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285      | @daveo, did you ever got your washers working? any tips/pics?? | ||
|  27th Oct 2014 3:41pm |
| Posting Rules
 i used a new pump from land rover as its a higher pressure than the standard one, only trouble is if you decide to buy the new pump you need the washer bottle aswel. might be worth trying the standard pump and seeing how it perfoms.
