Home > Maintenance & Mods (L322) > Smokey Exhaust |
arron Member Since: 22 Sep 2010 Location: lincolnshire Posts: 123 |
smoke on the td6 engine is generally caused by the engine breather assembley not being changed. |
23rd May 2012 1:05am |
Elena Member Since: 10 May 2012 Location: Coventry Posts: 42 |
Hi Arron
23rd May 2012 7:40am |
its simple enough to replace, take the engine cover off and look towards the rear of the engine. you need to undo the injector loom to get to it. once you bought your new breather it will be much easier to spot on the engine, its held on the engine by allan headed bolts. heres a link to one on ebay
24th May 2012 12:10am |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
Hi Elena.
24th May 2012 9:54am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34962 |
i to recommend removing the egr valve..better mpg and no smoke.. ... - .- -.
24th May 2012 10:41am |
Sea Aitch Member Since: 17 Feb 2011 Location: Hertford Posts: 120 |
+1 |
24th May 2012 12:47pm |
dito on the egr too, i dont want to feel left out. lol |
24th May 2012 11:50pm |
Isn't the EGR thing needed, if not could you talk me through how to remove it.
12th Jun 2012 5:55pm |
all in the wiki elena.. ... - .- -.
12th Jun 2012 5:58pm |
Hi Stan
12th Jun 2012 9:37pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
If you struggle im only up the road and have done the breather and egr a few times just drop me a pm if u get stuck onto no6 Range Rover
13th Jun 2012 11:03am |
Hi, I probably should have said that the smoke is blue in colour |
20th Jun 2012 9:13am |
check your oil level cos i think you might be burning it through worn piston rings or valves.. ... - .- -.
20th Jun 2012 9:18am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Not a fan of the devils fuel but blue smoke could be the turbo oil seals. Better than worn pistonrings and valves but still. OT the best. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
20th Jun 2012 10:15am |
