![]() | Home > Maintenance & Mods (L322) > Smokey Exhaust |
arron Member Since: 22 Sep 2010 Location: lincolnshire Posts: 123 ![]() ![]() ![]() |
smoke on the td6 engine is generally caused by the engine breather assembley not being changed. |
Elena Member Since: 10 May 2012 Location: Coventry Posts: 42 ![]() ![]() ![]() |
Hi Arron
its simple enough to replace, take the engine cover off and look towards the rear of the engine. you need to undo the injector loom to get to it. once you bought your new breather it will be much easier to spot on the engine, its held on the engine by allan headed bolts. heres a link to one on ebay
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
Hi Elena.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
i to recommend removing the egr valve..better mpg and no smoke.. ... - .- -.
Sea Aitch Member Since: 17 Feb 2011 Location: Hertford Posts: 120 ![]() ![]() ![]() |
+1 |
dito on the egr too, i dont want to feel left out. lol |
Isn't the EGR thing needed, if not could you talk me through how to remove it.
all in the wiki elena.. ... - .- -.
Hi Stan
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
If you struggle im only up the road and have done the breather and egr a few times just drop me a pm if u get stuck onto no6 Range Rover
Hi, I probably should have said that the smoke is blue in colour |
check your oil level cos i think you might be burning it through worn piston rings or valves.. ... - .- -.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Not a fan of the devils fuel but blue smoke could be the turbo oil seals. Better than worn pistonrings and valves but still. OT the best. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
