Home > Technical (L322) > Adjusting the resting position of the rear wiper.
5IMON
I tried changing the rear wiper last night.I stopped the wiper mid wipe and changed the blade . Consequentlly, after switching the engine back on, the wiper sits below the spoiler when it rests.
Any ideas guy would greatly appreciated it looks awful Sadu
51
Post #123483 24th May 2012 6:34pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Don't you remove the ignition key when it's mid-wipe or have I imagined that?
Post #123486 24th May 2012 6:42pm
5IMON
The first time I tried it I simply tried to stop the wiper as I remember reading that,that was what you had to do, however it prove unsuccessful . Only then did I resort to stopping the wiper mid-wipe by stopping the engine.
The wiper still does work perfectly fine though
Post #123488 24th May 2012 6:54pm
take the wiper off its spline and re-position it.. ... - .- -.
Post #123516 24th May 2012 9:57pm
5IMON
Thanks stan Thumbs Up
Post #123541 24th May 2012 11:23pm
Three 10mm bolts under the spoiler, then slide the spoiler off and then you can remove the cap undo the 13mm nut on the wiper arm and reposition...
Craig Thumbs Up
Post #123543 24th May 2012 11:28pm
5IMON
Does anyone know is you can replace the spindle if its worn or would it require a new motor?
I think its slipping you see
Thanks for the help Thumbs Up
Post #123546 24th May 2012 11:40pm
Don't think you can just replace the spindle.
The bay of fleas always have a few motors for sale! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #123549 24th May 2012 11:45pm
You may need to just tighten the 13mm nut on top of the wiper arm...
Craig Thumbs Up
Post #123552 24th May 2012 11:58pm
