![]() | Home > Technical (L322) > Adjusting the resting position of the rear wiper. |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 477 ![]() ![]() ![]() |
Don't you remove the ignition key when it's mid-wipe or have I imagined that? |
5IMON Member Since: 27 Nov 2011 Location: London Posts: 165 ![]() |
The first time I tried it I simply tried to stop the wiper as I remember reading that,that was what you had to do, however it prove unsuccessful . Only then did I resort to stopping the wiper mid-wipe by stopping the engine.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
take the wiper off its spline and re-position it.. ... - .- -.
Thanks stan |
Three 10mm bolts under the spoiler, then slide the spoiler off and then you can remove the cap undo the 13mm nut on the wiper arm and reposition...
Does anyone know is you can replace the spindle if its worn or would it require a new motor?
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
Don't think you can just replace the spindle.
You may need to just tighten the 13mm nut on top of the wiper arm...
