|  | Home > Technical (L322) > Adjusting the resting position of the rear wiper. |
| chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 479      | Don't you remove the ignition key when it's mid-wipe or have I imagined that? | ||
|  24th May 2012 5:42pm |
| 5IMON Member Since: 27 Nov 2011 Location: London Posts: 165  | The first time I tried it I simply tried to stop the wiper as I remember reading that,that was what you had to do, however it prove unsuccessful . Only then did I resort to stopping the wiper mid-wipe by stopping the engine.
|  24th May 2012 5:54pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | take the wiper off its spline and re-position it.. ... - .- -.
|  24th May 2012 8:57pm |
| 5IMON Member Since: 27 Nov 2011 Location: London Posts: 165  | Thanks stan  | ||
|  24th May 2012 10:23pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Three 10mm bolts under the spoiler, then slide the spoiler off and then you can remove the cap undo the 13mm nut on the wiper arm and reposition...
|  24th May 2012 10:28pm |
| 5IMON Member Since: 27 Nov 2011 Location: London Posts: 165  | Does anyone know is you can replace the spindle if its worn or would it require a new motor?
|  24th May 2012 10:40pm |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6839      | Don't think you can just replace the spindle.
|  24th May 2012 10:45pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | You may need to just tighten the 13mm nut on top of the wiper arm...
|  24th May 2012 10:58pm |
| Posting Rules
 u
u
