Home > Maintenance & Mods (L322) > Stubborn track rod end, help.
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
Cam-Tech-Craig wrote:
I have a set of stilsons that are a meter long!!! Purchased from a cheepy market stall and boy are they good at track rod ends... Whistle
Not found one stubborn enough yet!!!
Craig Thumbs Up
I'm off to our local sunday market to see if I can pick up a set of those, sounds the business Craig.
Thumbs Up The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #125121 6th Jun 2012 10:43am
Thumbs Up Thumbs Up Thumbs Up
Craig Thumbs Up
Post #125128 6th Jun 2012 11:54am
so how many thumbs have you got then craig... Laughing ... - .- -.
Post #125129 6th Jun 2012 11:59am
Enough to keep bashing with hammers each week Stan Laughing
Craig Big Cry
Post #125189 6th Jun 2012 6:18pm
Laughing Thumbs Up ... - .- -.
Post #125207 6th Jun 2012 7:29pm
ambulancekidd
Craig Big Cry
Rolling with laughter Rolling with laughter The reason women's minds are cleaner than a mans mind is that women change their minds more often!
Post #125237 7th Jun 2012 12:12am
ambulancekidd
The tale goes on. Today I put the Range Rover into the barn, up onto ramps & took stilsons (cheers for the idea Craig) along with a length of pipe for leverage to the stubborn track rod end nut, hey presto with some brute force & ignorance it moved. So I worked it back & forth til it would move with ease, Now feeling quite pleased with myself I took the nut off the top of the track rod end & put the ball joint splitter to work. It took a bit of effort but it came off with a resounding crack, woohoo I'm on a roll. I knocked the retaining ring off at the inner end, easy peasy. Just loosen off the track rod end itself & I'm home & dry. The car had other idea's, would the track rod end move? Not a chance matey. I tried everything I could think of including much gnashing of teeth with weeping & wailing before giving up. Big Cry
Its all back together now & it'll certainly go down to the workshop. The normal mechanic has been on holiday & is back next week. He car swear at it til his hearts content. Twisted Evil
Are all of these cars so stubborn to work on or have I just been unlucky? Rolling Eyes
Disgruntled Robert. The reason women's minds are cleaner than a mans mind is that women change their minds more often!
Post #125418 8th Jun 2012 8:13pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Sorry Robert you were just ticking the nut not got to the rod end yet!!!!
If the nut was that tight you have no chance with the rod end
My lock nut undid first time with a normal spanner so i thought I was on a roll to, better mail Dan for the new bits you will be needing! Mine was a blue one! Smile
Post #125419 8th Jun 2012 8:21pm
ambulancekidd
Me thinks your right. It'd save a lot of trouble, I'll go with your advice & do both sides too mate.
Post #125527 9th Jun 2012 10:43pm
