![]() | Home > Maintenance & Mods (L322) > Stubborn track rod end, help. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
so how many thumbs have you got then craig... |
Enough to keep bashing with hammers each week Stan |
ambulancekidd Member Since: 29 Feb 2012 Location: Ayrshire Scotland Posts: 276 ![]() ![]() ![]() |
![]() ![]() When women say fine a mans in deep doodoo as fine has so many meanings. |
The tale goes on. Today I put the Range Rover into the barn, up onto ramps & took stilsons (cheers for the idea Craig) along with a length of pipe for leverage to the stubborn track rod end nut, hey presto with some brute force & ignorance it moved. So I worked it back & forth til it would move with ease, Now feeling quite pleased with myself I took the nut off the top of the track rod end & put the ball joint splitter to work. It took a bit of effort but it came off with a resounding crack, woohoo I'm on a roll. I knocked the retaining ring off at the inner end, easy peasy. Just loosen off the track rod end itself & I'm home & dry. The car had other idea's, would the track rod end move? Not a chance matey. I tried everything I could think of including much gnashing of teeth with weeping & wailing before giving up. |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Sorry Robert you were just ticking the nut not got to the rod end yet!!!!
My lock nut undid first time with a normal spanner so i thought I was on a roll to, better mail Dan for the new bits you will be needing!
