Home > Maintenance & Mods (L322) > New Full Fat - tow bar recommendations please
burriana
England 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Here are a couple of pics of my new keep out of mischief card Smile
[url]
|http://thumbsnap.com/XNjTGjBx[/url]
[url]
|http://thumbsnap.com/LukDyw05[/url]
[url]|http://thumbsnap.com/8NibL8ld[/url]
[url]|http://thumbsnap.com/XYvaFjDR[/url]
One thing I do need is a tow bar. As it will be primarily for sticking a cycle rack on every now and again, it needs to be a removable one that looks as neat as possible when not in use. Any recommendations please?
http://www.witter-towbars.co.uk/product_re...e=01/09/06 can come and fit them for about £500, but it looks a bit big and cumbersome.
Or there is http:http://www.towbarexpress.co.uk/products.html which seem quite a good set up.
Any other options gratefully considered. Land Rover quoted over £1000! I was hoping for about £300.
Here is the underside of the car and it looks like it will be a start from scratch job:
[url]
|http://thumbsnap.com/qNWy2Kb1[/url]
I know there has been a recent post on this where it was suggested that it may not be the most cost effective way of transporting kids bikes but, at least if I have a good idea then I can make a call.
Someone also mentioned a site sponsor, Duckworth, who does such things. I tried the search but it came up with 700 odd links. Does anyone have a direct link please?
Thanks in advance. al Smile Aerodynamics are for those who cannot build engines - Enzo Ferrari
Post #125284 7th Jun 2012 4:20pm
burriana
Just saw by chance a link for Duckworth parts at true top of the page Smile Aerodynamics are for those who cannot build engines - Enzo Ferrari
Post #125285 7th Jun 2012 4:22pm
http://www.fullfatrr.com/forum/topic10990.html?highlight=tow+bar
http://www.fullfatrr.com/forum/topic9172.html?highlight=tow+bar
http://www.fullfatrr.com/forum/topic8513.html?highlight=tow+bar
http://www.fullfatrr.com/forum/topic8077.html?highlight=tow+bar ... - .- -.
Post #125286 7th Jun 2012 4:24pm
burriana
Thanks Stan - i had just started reading the first link Smile have also dropped Duckworth an email.
al Aerodynamics are for those who cannot build engines - Enzo Ferrari
Post #125287 7th Jun 2012 4:29pm
Oem is a witter bar comes in two types, detachable and flange.
The flange bar should be suitable for you and is cheaper, the bar fits into a sub assembly on the car (you will need this fitting for either) and can be fitted and removed as required by removing a couple of pins, and for occasional use will leave the rear end neater than the oem deatachable. There is nothing that can't be fixed with a hammer😜😜
Post #125293 7th Jun 2012 6:06pm
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
SNAP! Thumbs Up
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #125295 7th Jun 2012 6:19pm
simon1233
OEM is Westfalia, this link will show you the bits of metalwork that you need. You can add in the electrics through these guys but IIRC Dan (Duckworths) may be able to do better for the wiring loom. I believe that you want the Landrover loom as it is pretty much plug and play and should stop your rear parking sensors etc when a light board or trailer is plugged into it. Thumbs Up
http://www.pfjones.co.uk/range-rover-2005-...9DjH46LE04
This will give you the removable bar which just leaves a receiver visible when not being used. Alternatively you could go for the same armature but with the 'farmer's' multi-height bar which can also be removed when not in use. Downside to the farmers fitting is that it can 'clank' if you leave it in when not in use and if you do remove it - it takes up 1/4 of your boot space. The one in the link will fit into a special holder in the right hand side of the boot space where you probably have a storage bin at the moment. The holder should be supplied with the kit and even comes with the bolts to hold it in place Thumbs Up Thumbs Up
Post #125297 7th Jun 2012 6:30pm
^^^^ sorry thats what i meant. Must have been having a moment....
I have the westfalia detachable with the stowage tub in the boot, it is neat but the reciever does stick out a bit, if you went for the farmers/flange type bar then you will only Leave the sub frame and it will give more options re bike racks though storing it will be more problematic as said. There is nothing that can't be fixed with a hammer😜😜
Post #125310 7th Jun 2012 8:35pm
burriana
Thanks for the info guys.
It WILL be detached 99% of the time, so it needs to look as neat as possible without the tow ball attached.
Stowage of the tow bar section not a problem as I wouldn't keep it in the car, but custom fitting in the side pocket sounds quite neat.
Would you know where I might see a shot of both types with tow ball off and tow ball on?
I would be looking for someone to fit the whole lot in one go.
Cheers,
Post #125325 7th Jun 2012 9:51pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
The farmers hitch type is very neat when removed as the hole s filled with a plastic plug and is almost invisible. It also fits in the side "bin" in the boot. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #125337 8th Jun 2012 12:07am
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
For what its worth I think you would be better off with a 2" receiver hitch. Far more versitile
http://www.pfjones.co.uk/range-rover-2002-...w-bar.html
Gary
Post #125389 8th Jun 2012 3:01pm
Both OEM variants start with a receiver, but in the UK it's actually 50mm an not 2" (52mm).
The 'farmers' slides in receiver style and can be secured by a pin or a bolt. The 'detachable' style has a bespoke 2 part assemby - one part bolts into the receiver and the detachable bit fastens to it.
I've had both and prefer the farmers - as already stated, it looks much neater when removed - the down side is that when used with a pin, it can rattle a bit.
Post #125403 8th Jun 2012 5:39pm
Diagram of flange (aka farmers) - http://www.pfjones.co.uk/range-rover-2002-...9ItZmthiK0
And detachable - http://www.pfjones.co.uk/range-rover-2002-...9ItumthiK0
Post #125405 8th Jun 2012 5:52pm
stu
i will be watching for you in and around Harrogate, amongst all the other "Chelsea Tractors" as i travel there every day for work.
do you have a bike rack already? if not can i suggest one, which i think is superb!!
http://www.maxxraxx.co.uk/home.html
i have one of these and find it great. i can have the bikes on the carrier, the caravan hitched up and still open the boot to get the dogs in and out.. Thumbs Up Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #125440 9th Jun 2012 8:11am
burriana
Alistair wrote:
Diagram of detachable - http://www.pfjones.co.uk/range-rover-2002-...9ItumthiK0
That 5 second video on that page link looks just what i want, but my head is spinning about who to use for supply and fit.
Ideally I want one that can be supplied and fitted as a one stop shop, but I can't justify spending over £500 just on a tow ball for a bike rack a few times a year.
Duckworth's sent me a supply only quote for the parts and that came to £750 without electrics!
Halfords is looking good Sad Aerodynamics are for those who cannot build engines - Enzo Ferrari
Post #125948 13th Jun 2012 11:18am
