![]() | Home > Maintenance & Mods (L322) > New Full Fat - tow bar recommendations please |
burriana Member Since: 17 May 2012 Location: Harrogate Posts: 48 ![]() ![]() ![]() |
Here are a couple of pics of my new keep out of mischief card |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
http://www.fullfatrr.com/forum/topic10990.html?highlight=tow+bar
Thanks Stan - i had just started reading the first link |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Oem is a witter bar comes in two types, detachable and flange.
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 ![]() ![]() ![]() |
SNAP! |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
OEM is Westfalia, this link will show you the bits of metalwork that you need. You can add in the electrics through these guys but IIRC Dan (Duckworths) may be able to do better for the wiring loom. I believe that you want the Landrover loom as it is pretty much plug and play and should stop your rear parking sensors etc when a light board or trailer is plugged into it. |
^^^^ sorry thats what i meant. Must have been having a moment....
Thanks for the info guys.
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
The farmers hitch type is very neat when removed as the hole s filled with a plastic plug and is almost invisible. It also fits in the side "bin" in the boot. No longer FF owner but still interested. Present car Jaguar XE
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
For what its worth I think you would be better off with a 2" receiver hitch. Far more versitile
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
Both OEM variants start with a receiver, but in the UK it's actually 50mm an not 2" (52mm).
Diagram of flange (aka farmers) - http://www.pfjones.co.uk/range-rover-2002-...9ItZmthiK0
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
i will be watching for you in and around Harrogate, amongst all the other "Chelsea Tractors" as i travel there every day for work.
That 5 second video on that page link looks just what i want, but my head is spinning about who to use for supply and fit. Ideally I want one that can be supplied and fitted as a one stop shop, but I can't justify spending over £500 just on a tow ball for a bike rack a few times a year. Duckworth's sent me a supply only quote for the parts and that came to £750 without electrics! Halfords is looking good ![]() |
