![]() | Home > Off Topic > Light transformer and dimmer |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I've just fitted some new wall lights, and once the power was on the lights worked, but as I dimmed them the transformers blew. Quick look at the instructions and it says not suitable for dimmers. |
Each light fitting has its own transformer, and has 3 of the small halogen bulbs in it. I don't understand why each one blew when dimmed and the one in the lounge are the same set up and are ok? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
If the transformers are in the primary they should dim ok.
They did light but then popped. How do I identify the primary? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
If you have the transformers in the mains voltage supply they are in the primary circuit.
Turbo Tony Member Since: 06 Apr 2010 Location: London Posts: 243 ![]() ![]() |
Sounds to me like the transformer's primary connections are the wrong way around. Researching my first Range Rover purchase |
Is there a way to find this out? Or just have a look? They lit with the dimmer turned to full then blew when turned down. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
