Home > Off Topic > Light transformer and dimmer
I've just fitted some new wall lights, and once the power was on the lights worked, but as I dimmed them the transformers blew. Quick look at the instructions and it says not suitable for dimmers. Censored . I then looked at the ones I had fitted in the lounge and they say the same but are working fine on a dimmer. The transformers in the lights are Hui Bo Long HTV60CL1 and I've found them online for about £18, but the data sheet says they can be used on a dimmer if it's on the primary. I have the dimmer on the supply so why are have they blown and the others haven't? Any ideas? I would like to keep the dimmer as they're in the dinning room and obviously good for mood lighting etc. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #127239 22nd Jun 2012 8:41pm
Each transformer will take maximum 60W load whether on the primary or secondary circuit.
I presume therefore you only have 60W of lighrting on each transformer, if more than this the transformer will be over loaded.
Normally it would be advisable to use 1 transformer per lamp fitting.
60W is not a lot for tungsten halogen lighting.
Post #127242 22nd Jun 2012 8:59pm
Each light fitting has its own transformer, and has 3 of the small halogen bulbs in it. I don't understand why each one blew when dimmed and the one in the lounge are the same set up and are ok? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #127247 22nd Jun 2012 9:24pm
If the transformers are in the primary they should dim ok.
Assuming the fittings and bulbs are ok I would change a transformer from the lounge to the dining room and see what happens.
Its not inconceivable you have been supplied with faulty transformers.
Post #127248 22nd Jun 2012 9:43pm
They did light but then popped. How do I identify the primary? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #127249 22nd Jun 2012 9:47pm
If you have the transformers in the mains voltage supply they are in the primary circuit.
Secondary refers to the 11.5V circuit.
Post #127250 22nd Jun 2012 10:04pm
Turbo Tony
Sounds to me like the transformer's primary connections are the wrong way around. Researching my first Range Rover purchase
Post #127329 23rd Jun 2012 7:09pm
Is there a way to find this out? Or just have a look? They lit with the dimmer turned to full then blew when turned down. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #127332 23rd Jun 2012 8:32pm
