Home > Maintenance & Mods (L322) > DRL's in foglights
Heyloft
2019 Range Rover Vogue SE SDV8 Carpathian Grey
I don't think that SMDs are suitable to replace the existing headlight LEDs they don't look like SMD, but then again I haven't taken my headlight apart yet.
I was kinda hoping someone else already had Whistle Wot's that in old money
Post #123046 22nd May 2012 3:23pm
klf400
i have a damaged 2012 headlight in the workshop and it looks as the plastic lens is bonded to the rear houseing
there is some lugs top and bottom that looks as if you can unclip them , but they are bonded as well if you could melt the glue then maybe
i will give it a go and see if it will melt as the lens is cracked so it doesnt matter Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #123696 26th May 2012 7:29am
Heyloft
It's glue I guess. Needs a gentle heating with a heat gun all the way round.
There is a link and pics on the D3 forum, but I can't find them again right now !
I would be great to find out Wot's that in old money
Post #123699 26th May 2012 7:53am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Got around to fitting the LED's into the fogs quite pleased with the result.
Other members have done good write up's on how to do it but my 10p's worth.
My reflectors were shot with the surface all flaking off. I will need new ones but a temporary fix is aluminium foil duct tape. It can be worked into shape without to many creases and then given a polish, not quite good as new but good enough.
I wanted my LED's to sit at the back of the light against the reflector. the fog light housing is tapered the 80mm diameter Leds are a tight fit at the reflector end so I had to file/sand them down to a nice fit as if you force them they break! Big Cry
I also managed to get Led's with a black background so they are less noticable when off.
Relay came from the bay of E It was supposed to be a voltage sensing type that could go onto a permanant live and turn on and off when the voltage went up when the engine was running it also has a switch wire for side/headlights to turn the DRL's off when they are on as per the rules. However it was faulty and just stayed on engine running or not so I just fed it with an ignition switched feed from the nearside headlight as per Joe 90's earlier post. Mine was a blue one! Smile
Post #128909 2nd Jul 2012 12:20pm
looks good andy.. Thumbs Up ... - .- -.
Post #128926 2nd Jul 2012 1:40pm
Andy3681
Thank you Thumbs Up
quite please with myself ( smug mode engaged)
And the foglights are un affected Mine was a blue one! Smile
Post #128935 2nd Jul 2012 2:23pm
you'll find yourself looking into windows and backs of cars to see if they are still working...i done mine about 18 months ago and still do that.. Laughing ... - .- -.
Post #128937 2nd Jul 2012 2:27pm
Andy3681
Been doing that all morning but need to find polished cars to follow.
Dont you always look at your FF in shop windows???? Surprised
I think thats a thread all on its own Thumbs Up Mine was a blue one! Smile
Post #128939 2nd Jul 2012 2:32pm
Laughing
Post #128940 2nd Jul 2012 2:35pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Citroen C4's are one of the best cars to follow in a RR. You can see yourself driving in their shiny rear windows (ooh er missus) Thumbs Up
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #128945 2nd Jul 2012 3:08pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I spent a few hours this afternoon completing this mod.
I love it Cool
Post #129437 4th Jul 2012 7:13pm
