Home > Technical (L322) > Magna Steyr DD295 Transfer Box Teardown |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 912 |
I’ve just bought a poorly DD295 transfer box off eBay for £50 as I thought it might be fun to strip one down to see what’s what. The seller’s description was that it “did drive but was noisy” and I can tell just from spinning the input shaft by hand that there’s something very wrong inside – it feels extremely rough.
7th Jul 2012 9:40pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Great stuff Phil .
7th Jul 2012 10:07pm |
Still hitting the refresh button |
7th Jul 2012 10:14pm |
Phil on behalf of the forum members here,
7th Jul 2012 11:05pm |
7th Jul 2012 11:41pm |
Unfortunately it’s not an option to swap the two transfer boxes as they were never designed to mate up to the same transmission. I would imagine that their installation sizes are different too. Also, their control systems will be quite different as the passive Torsen centre diff. in the NV225 was replaced with active clutch control in the DD295.
8th Jul 2012 12:01am |
Thanks Phil, I'm off to bed right now |
8th Jul 2012 12:44am |
The two halves of the casing separate easily with almost all of the components staying with the rear casing
8th Jul 2012 11:50pm |
Really interesting Phil, I take it the bearing is the only problem you've found so far? |
9th Jul 2012 12:56pm |
Yes, just that input bearing – and I strongly suspect that’s all I’m going to find wrong with it. None of the box’s internal parts are available from Land Rover so I’ll get the bearing out, check its size and get a price from a local bearing factor (just out of interest).
9th Jul 2012 7:39pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
Is it just a lack of fluid that has caused the bearing to fail? |
9th Jul 2012 11:20pm |
Thanks Phil, top post |
9th Jul 2012 11:32pm |
The failed input bearing turns out to be a plain, single row, deep groove ball bearing of size 50 x 90 x 20.
18th Jul 2012 12:28am |
Any idea of the bearing failure Phil?
18th Jul 2012 2:24pm |
