![]() | Home > Technical (L322) > Range Rover Key Transponder |
andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102 ![]() ![]() ![]() |
if you lost all keys with PCF7936AS can be generate through two tools, one for reading EWS ECU and one for writing b,lank transponder
ok, got a big massive eye glass and my chip is a PCF7903AS .. i just want to make a second key. V8 facelift Range Rover Autobiography 22" wheels.
Here ?: http://www.ecutool.com/EWS-Editor-V320_6202.html .
I'm sorry for delay, due so much work this week, but Joe put the correct link for EWS EDITOR
hi Andrew, what other tool did you use to write the chip or did the ews editor do the whole job... i have done a bit of looking on the net and it seems to be quite straight forward, did you come across any problems
I bought ews editor because I lost all keys so I needed to read from ews than generate transponder.
