Home > Technical (L322) > Towbar options.
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Towbar options.
Sorry if this is covered somewhere else, but I did a search and couldn't find what I needed.
I'm considering borrowing a mates caravan for Carfest, but I don't have a towbar on my 2007 S/C.
I've had a look at the back and I have a tow eye on the right hand side and there's a female plug for the electrics, but I can't see anywhere for a tow ball to slot in.
What are my options? I know there's a detatchable towbar available for the FF - but how do I know if I've got the right plumbing for this?
Bit confused about what I'd need to buy....thanks in advance! Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #132499 23rd Jul 2012 2:01pm
if you have one of these [see pic]
then you can buy a armature/towbar and fit it into the 2'' square hole..the electrics 'should' be to the left sort of under the bumper..
if you havnt then its a complete new install jobby... ... - .- -.
Post #132501 23rd Jul 2012 2:12pm
jfb1977
Nope, don't have one of those.
I do have the electric (13 pin) connector, but can't see anything for a tow bar. Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #132505 23rd Jul 2012 2:23pm
strange you have the electrics but not a towbar... ... - .- -.
Post #132506 23rd Jul 2012 2:26pm
jfb1977
I assume that this is the plug for the electrics -
And there's a Westfalia metal frame at the back which the towing eye is part of, but I can't see anything central for a tow bar / two ball. I just have 2 holes on either side like this (top of the photo is the back of the car) -
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #132509 23rd Jul 2012 2:44pm
i think you might have the 'structure' for a towbar but not the towbar itself...havnt seen one of these before sorry...you could pop into a towbar fitting centre and ask.. ... - .- -.
Post #132511 23rd Jul 2012 2:50pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
That is part of the mounting bracket. There should be one each side with a horizontal bar running between them. Normally in the middle of the bar is a square hole for slotting in a tow bar. The hole may be filled in with a square plastic plug with Land Rover written on it. If you have that fitted, just prise the plug out with a screw driver or similar. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #132512 23rd Jul 2012 2:51pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
The two brackets that are removed, when fitting a towbar, are also made by Westfalia
Post #132513 23rd Jul 2012 2:52pm
jfb1977
So it looks like I might have part of the kit, but not all of it.
I'm missing the horizontal bar. Hmmm.... Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #132514 23rd Jul 2012 2:53pm
Mikeyjd
The bar doesn't look like it will remove. The whole lot appears to be welded. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #132515 23rd Jul 2012 2:54pm
nbunney
Nope, the towbar is a 1 piece item.
Post #132516 23rd Jul 2012 2:55pm
nbunney
This may make it clearer if you have a look here:
http://www.pfjones.co.uk/range-rover-2005-flange-tow-bar-1.html
Post #132517 23rd Jul 2012 2:57pm
jfb1977
Ok, have sorted it. I need Westfalia part no. eBay Item No. 323074600001 for the tow bar and then I need to buy the tow ball too.
Too expensive for one weekend...
Anyone with a towbar want to swap their car for an S/C for the weekend in August? Laughing Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #132519 23rd Jul 2012 3:01pm
nbunney
I'll buy your electrics and ecu off you then Thumbs Up
Post #132520 23rd Jul 2012 3:03pm
