![]() | Home > Technical (L322) > Towbar options. |
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 ![]() ![]() ![]() |
Sorry if this is covered somewhere else, but I did a search and couldn't find what I needed.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
if you have one of these [see pic]
Nope, don't have one of those.
strange you have the electrics but not a towbar... ... - .- -.
I assume that this is the plug for the electrics -
i think you might have the 'structure' for a towbar but not the towbar itself...havnt seen one of these before sorry...you could pop into a towbar fitting centre and ask.. ... - .- -.
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2073 ![]() ![]() ![]() |
The two brackets that are removed, when fitting a towbar, are also made by Westfalia |
So it looks like I might have part of the kit, but not all of it.
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
The bar doesn't look like it will remove. The whole lot appears to be welded. No longer FF owner but still interested. Present car Jaguar XE
Nope, the towbar is a 1 piece item. |
This may make it clearer if you have a look here:
Ok, have sorted it. I need Westfalia part no. eBay Item No. 323074600001 for the tow bar and then I need to buy the tow ball too.
I'll buy your electrics and ecu off you then |
