![]() | Home > Technical (L322) > brakes squealing |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
you need to put copperslip on the back of the shims or pads... ... - .- -.
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
Chamfering the leading edges of the brake pads at 45 degrees with a file often cures brake squeal. Might be worth a try. |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Stans copper grease idea is the way to go. Will sort it out. Also put a bit on the join between wheel and disc, makes removing the wheels so much easier. Have had an alloy weld itself on to my old landcruiser. Had to use a lump hammer to get it off. There is nothing that can't be fixed with a hammer😜😜
| paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222
What pads did you fit? Had the squealing meself after fitting aftermarket (Mintex) pads on the front. Tried all the usual tricks to shut them up as described in the earlier posts. Even tried some aftermarket stick-on shims that are advertised as curing this problem. Zilch, so ordered the OEM pads from Dan. £60 I think, cured it straight away, and its never returned. Of note, whilst driving, I would have sworn that the squeal was coming from the rears- I got a mate to check, confirmed it was the front end.
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
I fitted a set of non OE front pads last year and they sounded like a London bus every time I touched the pedal, tried chamferring the edge and copper grease on the ack to no avail. I ended up buying a new set of pads from Dan and solved the problem |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
You could try bedding the brakes in "heavily"
| Lloyd Barnes Member Since: 21 Apr 2011 Location: Shrewsbury Posts: 181
I had the same issue with mine. Sounded like at train stopping at crawling speed. Very embarrassing in queues or at Starbucks drive through!! |
| andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540
Thanks guys, will let you know how I get on. I will try the coppergrease first. |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
On my car it happens only sometimes, usually in wet conditions with "light" breaking. I suggest the "braking in" method as well to "clean" the surface and "bed" the pads in.
| All times are GMT |
