|  | Home > Technical (L322) > brakes squealing |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885    | you need to put copperslip on the back of the shims or pads... ... - .- -.
|  23rd Jul 2012 7:39pm |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989      | Chamfering the leading edges of the brake pads at 45 degrees with a file often cures brake squeal. Might be worth a try. | ||
|  23rd Jul 2012 8:06pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Stans copper grease idea is the way to go. Will sort it out. Also put a bit on the join between wheel and disc, makes removing the wheels so much easier. Have had an alloy weld itself on to my old landcruiser. Had to use a lump hammer to get it off. There is nothing that can't be fixed with a hammer😜😜
|  23rd Jul 2012 8:13pm |
| paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222    | What pads did you fit? Had the squealing meself after fitting aftermarket (Mintex) pads on the front. Tried all the usual tricks to shut them up as described in the earlier posts. Even tried some aftermarket stick-on shims that are advertised as curing this problem. Zilch, so ordered the OEM pads from Dan. £60 I think, cured it straight away, and its never returned. Of note, whilst driving, I would have sworn that the squeal was coming from the rears- I got a mate to check, confirmed it was the front end.
|  23rd Jul 2012 9:55pm |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    | I fitted a set of non OE front pads last year and they sounded like a London bus every time I touched the pedal, tried chamferring the edge and copper grease on the ack to no avail. I ended up buying a new set of pads from Dan and solved the problem | ||
|  24th Jul 2012 9:37am |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | You could try bedding the brakes in "heavily"
|  24th Jul 2012 10:09am |
| Lloyd Barnes Member Since: 21 Apr 2011 Location: Shrewsbury Posts: 181      | I had the same issue with mine. Sounded like at train stopping at crawling speed. Very embarrassing in queues or at Starbucks drive through!!   | ||
|  24th Jul 2012 11:23am |
| andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540      | Thanks guys, will let you know how I get on. I will try the coppergrease first.  | ||
|  24th Jul 2012 1:04pm |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782      | On my car it happens only sometimes, usually in wet conditions with "light" breaking.  I suggest the "braking in" method as well to "clean" the surface and "bed" the pads in.
|  24th Jul 2012 1:13pm |
| Posting Rules
