Home > Technical (L322) > brakes squealing
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
brakes squealing
Hi all, just changed the brake pads on all corners,replaced the sensors, discs all ok, got rid of the error code job done i thought, after a couple of days every time i brake i get an annoying squeal, I have bedded the brakes in gently and avoided any heavy breaking. Any suggestions?
Post #132571 23rd Jul 2012 7:42pm
you need to put copperslip on the back of the shims or pads... ... - .- -.
Post #132578 23rd Jul 2012 8:39pm
Chamfering the leading edges of the brake pads at 45 degrees with a file often cures brake squeal. Might be worth a try.
Post #132582 23rd Jul 2012 9:06pm
Stans copper grease idea is the way to go. Will sort it out. Also put a bit on the join between wheel and disc, makes removing the wheels so much easier. Have had an alloy weld itself on to my old landcruiser. Had to use a lump hammer to get it off. There is nothing that can't be fixed with a hammer😜😜
Post #132585 23rd Jul 2012 9:13pm
paneldamage
What pads did you fit? Had the squealing meself after fitting aftermarket (Mintex) pads on the front. Tried all the usual tricks to shut them up as described in the earlier posts. Even tried some aftermarket stick-on shims that are advertised as curing this problem. Zilch, so ordered the OEM pads from Dan. £60 I think, cured it straight away, and its never returned. Of note, whilst driving, I would have sworn that the squeal was coming from the rears- I got a mate to check, confirmed it was the front end.
After removing the Mintex pads, I could see what looked like metal strands embedded in the material of the pad.
Post #132598 23rd Jul 2012 10:55pm
I fitted a set of non OE front pads last year and they sounded like a London bus every time I touched the pedal, tried chamferring the edge and copper grease on the ack to no avail. I ended up buying a new set of pads from Dan and solved the problem
Post #132635 24th Jul 2012 10:37am
You could try bedding the brakes in "heavily"
0-60 then 60 -5mph without skidding @ 7 times, and don't sit on the brakes once finished. Makes a lovely smell. I'll find the post from SteveMfr about this.
Here it is:
http://www.fullfatrr.com/forum/post113210.html#113210
Also, have Mintex fitted all round on my FFRR , no squeaks, squawks, or squeals Smile .
Post #132644 24th Jul 2012 11:09am
Lloyd Barnes
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
I had the same issue with mine. Sounded like at train stopping at crawling speed. Very embarrassing in queues or at Starbucks drive through!! Embarassed
Agree that most times its just the last fitter was too lazy to copper slip the pads. However in my case they were liberally coated. New pads and discs cured it. Picked them up from euro parts after a tip on here that they had (have) a promo on. Lloyd Barnes
Current
Crendon 427 Sideoiler Cobra in build... 7 litres of madness!
Gone
2008 TDV8 Vogue - Black with Ivory/Grand Black Lacquer
2008 VW Touareg 3.0Tdi
6.3litre Dax Cobra - 12.34 Second 1/4mile at 114mph Smile
Post #132654 24th Jul 2012 12:23pm
andyboy
Thanks guys, will let you know how I get on. I will try the coppergrease first. Thumbs Up gone fishin'
Post #132672 24th Jul 2012 2:04pm
ebajema
On my car it happens only sometimes, usually in wet conditions with "light" breaking. I suggest the "braking in" method as well to "clean" the surface and "bed" the pads in.
Also, please go gentle on the copper grease, too much and it can end up on the discs. Now while that would stop the squealing, it would also stop the braking itself ;( MY 2010 5.0 SC Galway green and sand interior!!
Post #132674 24th Jul 2012 2:13pm
