![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
| Aurrian Member Since: 29 Aug 2011 Location: Glasgow Posts: 107
My IID Tol just arrived. Got it updated and been out to play |
| TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848
Follow me home usually requires a flash of the main beams to activate the timer |
Ah - that makes sense thanks. Wife's got an audi and they just come on automatically so was expecting that.
| PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153
Hi Guys
The feedback is justified.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Thank you Patrick Craig |
| CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528
What is hot and cold monitoring ? I presume it's something to do with checking for a malfunctioning bulb, but not sure of the difference between the two.....
Check your service book then reset? Craig |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
un-install the gap software from the 'program' feature in your computers control panel, then re-install as a new program... ... - .- -. Y. O. L. O. . |
| Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244
Hot monitoring is when the LCM checks the bulbs when the lights are switched on. Cold monitoring is when the LCM checks the bulbs when the lights are switched off. I guess you will still need some resistors to stop the indicators flashing double speed, or would turning off the checking solve the issues of adding the LED lights in a conversion? Tom Current Drive 2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather Previous Drives 2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather 1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather 1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic |
| MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 643
Eerrr yeah thanks Craig. Anyway no worries cos Patrick and co have done a fantastic job of adding the feature so I know that the distance to go until the next service is due is about 700miles. Just as you thought?
It really has been an impressive response - not just in engaging with the request but also in the speed and helpful manner in which they've done it. Exemplary guys. Many thanks. Mike - MPx 2017 5.0 V8 Supercharged SVAutobigraphy Dynamic SVO Palette Grey (2021-...) 2012 5.0 V8 Supercharged Autoboigraphy Orkney Grey (2017-2021) 2007 4.2 V8 Supercharged Vogue SE Tonga Green (2012-2017) 2002 4.4 V8 Vogue Bonnatti Grey (2008-2012) |
Well the obvious answer would be service due in August as its a yearly service if adequate mileage has not been achieved... |
I was driving up to the Isle of Skye yesterday with my family for our summer holiday, the SC was full laden, 4 bikes on the back and was effortless, then the EML light came on but still driving fine...
| PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877
I think that is an O2 sensor. Won't do any harm in driving with that fault, enjoy your holiday! |
