Home > In Car Electronics (L322) > ELM Bluetooth OBD + Torque (Android)
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Hi,
Anyone else using this setup? I am amazed at what it can do, apart from giving my instantaneous and trip mpg (the thing I missed when I traded from my 2010), it does 0-60 timings, 1/4 mile, rough HP etc etc. More dials than you could imagne and readouts. Graphing, map as you go, and it has various plugins.
Totally configurable and portable between vehicles.
This morning on the drive to work I tried command shift to keep it in the highest gear possible (6th), gained 1mpg over the same journey in D (letting the car decide the gear).
Anyway - the upshot - if you are techno geek and have a large phone (HTC One-X, Galaxy Note) or an android tabled - get one!
I have mine mounted using a cup holder suction mount(£5 bay of E), and a HTC One-X suction holder (£1.99) - places the phone to the front left of the gearshift. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #133715 31st Jul 2012 9:54am
they do sound pretty good neil, but i seem to recall reading somewhere that if you leave the bluetooth unit in the obd port permanently, it 'might' drain the battery.. ... - .- -.
Post #133722 31st Jul 2012 11:06am
DMRR
Hi Stan,
Easy enough to remove, but once the car is off the little device is unavailable, which to me means it's off. However, I don't leave it in all the time - it stows nicely under the top of the cubby on the left Smile Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #133723 31st Jul 2012 11:10am
DMRR
Last night did a standing start with DSC on - 0-60 9.1s 1/4m 17.1, 310hp at 3650rpm.
Quite a giggle. I'm sure I could get that down Wink Not bad for a 3 ton oil burner tbh. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #133725 31st Jul 2012 11:12am
fisha
Regarding draining battery, the obd port does have a permanent supply, it will power my diagnostic unit with the ignition off.
So I guess it's down to each device design and whether it will drain battery.
Btw,
Does torque show coolant temp
What about transmission temp? V8 or else ...
Post #134133 2nd Aug 2012 10:49pm
DMRR
Torque shows coolant temp. I'll have a look to see if has the transmission temp. Basically if the PID's are there for it, it will read it.
By the way, has anyone noticed that the OBD port cover has three pins in it that sit in the port when it's closed? I wonder if that is to shut off the supply? Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #134151 3rd Aug 2012 9:17am
when closed, the port cover does indeed switch off the supply neil.. Wink ... - .- -.
Post #134155 3rd Aug 2012 9:25am
DMRR
Oddly the Freelander doesn't have this requirement (the pins...) Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #134156 3rd Aug 2012 9:27am
from memory, there have been a few members on the forum that have had battery drains and it was down to the obd port cover being open.... ... - .- -.
Post #134157 3rd Aug 2012 9:33am
DMRR
Hmmmm interesting. Bear in mind that the OBD cover on the 2007MY -> interferes with the accelerator (well your foot at least!) so I'm guessing these were pre 2007 vehicles (or people with tiny feet!). I wonder why the RR needs to be told to shut it down when other cars do not. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #134158 3rd Aug 2012 9:39am
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
Which ELM would you recommend?
Which android app is compatable ?
It looks really interesting after watching it on YouTube.
Post #134860 7th Aug 2012 10:40pm
DMRR
ELM : http://www.ebay.co.uk/itm/261043849303?ssP...1439.l2649
Any app that can read OBD over bluetooth. Torque Pro is the best I have found (there is a free version called Torque Lite). Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #134930 8th Aug 2012 10:47am
goldsax
Post #134931 8th Aug 2012 10:53am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Did the OBD module not get in the way of your accelerator foot? Also how did you launch your FFRR? I can't decide if I just floor it and hope the auto-handbrake lets go, or try using the old footbrake + accelerator trick (american style).
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #134947 8th Aug 2012 12:04pm
DMRR
I just floored it. Will have another play again on a better road.
As for the unit - the only thing that interferes is the cover for the OBD port, so either tape it up (i.e. open it all the way and back on itself), or take it off. Once the cover is not hanging down, the unit is small enough not to bother you. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #134949 8th Aug 2012 12:27pm
