Home > Technical (L322) > Magna Steyr DD295 Transfer Box Teardown
Page 2 of 9 <123456789>
RRPhil
My current theory is that the Magna engineers will have specified ‘proper’ bearings for their transfer box but then their procurement people found some nice cheap ones from Slovakia, and these are not up to the task. This theory is based on a sample of one and I may well be proved wrong on this! I still find it interesting that Magna have chosen to axially preload this input bearing (with two disc springs/Belleville washers) - makes you wonder if they saw issues with this bearing during development?
The two halves of the casing come apart easily. The Land Rover dealers are ‘allowed’ to do this as it’s a necessity for the replacement of the front & rear driveshaft flange seals. There’s no paper gasket for the joint face – just sealant.
Phil
Post #131820 18th Jul 2012 3:17pm
T24RES
Pm sent Phil
Post #133831 31st Jul 2012 9:42pm
RRPhil
I’ve never tried removing one of these transfer boxes myself. From the workshop manual it appears pretty straightforward but it looks as though the top four bolts are a pain to access and Land Rover recommend a special tool (wrench adaptor) :
Phil
Post #133849 31st Jul 2012 11:16pm
Mine was also weeping from the seal, all repaired by lr under warranty.
Interesting write up Phil. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #133852 31st Jul 2012 11:34pm
Stormin
2003 Range Rover HSE Td6 Epsom Green
Makes great reading
Thanks Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #133959 1st Aug 2012 4:01pm
RRPhil
I’ve finally got around to dismantling the combined centre differential & low range reduction epicyclic assembly.
The assembly just slides out of the shifting sleeve :
which stays in place, retained by the shift fork :
but can then be twisted & turned to release it from the shift fork’s sliding blocks :
The six E12 Torx bolts can be removed (with some difficulty - the threads being micro-encapsulated with Loctite) to release the end plate from the differential assembly :
The rear output flange bevel drive gear then lifts out :
to reveal what can only be described as a triumph of packaging by the Magna engineers where they’ve managed to integrate the 50:50 front/rear bevel gear differential and the reduction epicyclic for low range into the same unit :
The annulus gear for the reduction gearing, which is either earthed to the casing by the shifting sleeve for low range or connected to the carrier to lock the whole assembly together for high range (1:1), slides off :
The triple-planet reduction epicyclic tooth numbers are 43T sun, 21T planet, 83T annulus giving a reduction ratio for low range of (83+43)/43 = 2.93023256
There are synchronisers clipped to both the carrier and the earthing point into which the two ends of the shifting sleeve slide to accomplish the smooth engagement of each range :
Phil
Post #134502 5th Aug 2012 5:29pm
An excellent write up Phil.
Once you have successfully rebuilt it you can have mine for a strip down Thumbs Up
Post #134504 5th Aug 2012 5:33pm
gruodiz
Very interesting, informative write up Phil. I really like to read this one and ZF 6HP26 write ups.
I have changed these simple shaft bearings couple months ago and I would like guys to know in future that 6210 C3 from ZKL is specially designed for this transfer box as this bearing with C3 has special inner bearing egde cut.
When i found this bearing failed and saw ZKL i though that replace with SKF is much better and bought set of all four bearings (if I remember 6209 6210 6211 6212) from SKF but then realised that SKF inner ring does not have that cut edge and can not fit to its place so I went to other local bearing specialist and was lucky to find out that they will deliver that C3 bearing in one day.
Phil you're top mate Thumbs Up
Post #202351 4th Aug 2013 8:57pm
RRDEL
United States
Fabulous post Phil!
I have the same transfer case with a stretched chain (like the old ones).
Trying to find a chain. Any suggestions?
Post #247624 11th Mar 2014 9:27pm
RRPhil
I believe that Cobra Transmission (Miami) stock the chains
http://cobratransmission.com/index.php?mai...d=55166008
Phil
Post #247640 11th Mar 2014 10:38pm
Hi phil,
Having to have my transfer box sealed for the 3rd time, as it keeps leaking from the silicone gasket!
Any idea what the best gasket silicone is, as i will get some and throw it in the direction of the dealership....
They just dont seem to be able to get it right and it fails after a few months. Not sure what they might be dong wrong apart from not using enough silicone, not letting it sit for a few mins before mating the faces or torquing it immediately, as opposed to letting it set up for an hour fingertight/5lbft.
Any ideas methods for making this a good seal would be gratefully received. Im half thinking of getting a refubished one to give them to fit! There is nothing that can't be fixed with a hammer😜😜
Post #258551 10th May 2014 9:04am
wealy
I'm on my third seal too - mine turned out to be a crack in the casing.
Give me a callt
Post #259289 13th May 2014 10:42pm
wealy
Hi Phil.
have you heard of porosity in the casing? Or even a crack?
I have a re-occuring oil leak issue?
Post #259385 14th May 2014 2:50pm
wealy
bump
Post #260527 20th May 2014 4:53pm
RRPhil
Yes I have, though I’m struggling to find the information again. It may have been from a Discovery or RR Sport bulletin board because they use the same transfer box. I definitely recall seeing photos of cracked/porous transfer box casings and they’d been like that since new. I’ll see if I can find it again.
Phil
Post #260808 21st May 2014 11:50pm
