Home > Technical (L322) > I need a new remote shell ?
Marksman
Hi,
the rubber buttons on my spare key are disintegrating, there are new cases on Fleabay easy enough to swap over the innards and the transeiver but where will I get the blade cut ? Exclamation
Post #133811 31st Jul 2012 8:40pm
Re: I need a new remote shell ?
Any decent key cutting shop can cut BMW keys... Thumbs Up
Craig
Post #133855 1st Aug 2012 12:42am
awclymm
Marksman wrote:
Hi,
Why get a new blade? Just swap the one you currently have into the new casing.
Post #134057 2nd Aug 2012 9:51am
Any Timpsons shop or mobile caravan will cut the blade for you.
Usually located in supermarket carparks.
I got a new shell for the same reason and had the blade cut at a Timpsons van. Worked first time.
Post #134058 2nd Aug 2012 10:05am
ebajema
On the bay of flees you can also find "reconditioning" kits that replace the rubber. I think they come from Oz when I looked at keys and the likes last. That way you can retain your current key, no blade cutting or other issues Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #134059 2nd Aug 2012 10:42am
verydisco
The OZ kit is good but is not EOM looking.
For the same price, online, you could get a new key shell and blade that will need to be cut - however just keep the soft rubber part for you current key and switch the torn out original soft rubber part for the new OEM looking.
Did it on my Td6, worked a treat. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #134067 2nd Aug 2012 11:49am
Having subsequently taken my original key fob shell to pieces with a view to looking into replacing the rubber buttons only, as a second spare, I found the origonal rubber buttons are fitted into the fob in such a way it is almost impossible to remove them satisfactorily and I would defy anyone to then replace new rubbers in a truly satisfactory manner.
Much better result just getting a replacement case and getting the blade cut.
Post #134068 2nd Aug 2012 11:52am
verydisco
http://t0.gstatic.com/images?q=tbn:ANd9GcQ...UfJwkeCqHw
Oh, well, I did this a long time ago with satisfactory result - easy win really. LOL!
Just be calm and patient when doing it. it still takes less time than going to the shop to get a blade cut anyway. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #134069 2nd Aug 2012 12:02pm
Thumbs Up Very Happy
I've still got the origonal fob, how do you get the new rubber buttons in in a similar manner to original?
Post #134070 2nd Aug 2012 12:08pm
verydisco
You need to alter the new rubber part so it fits nicely.
As you said, you can not put it exactly how it was, the shell and the rubber part being almost "molded" together.
However once you have both the original key and the aftermarket shell opened, you will see one can alter the rubber part with an X-acto blade to get it to fit flush.
It wont be as waterproof as the original one - however you could use sealant - but when was the last time you dropped your key in water... l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #134072 2nd Aug 2012 12:12pm
Hmm, I did think about doing what you describe but came to the conclusion that using a new fob and having the blade cut would achieve a more satisfactory result.
As long as we both got a result we wanted that's satisfactory. Thumbs Up
Post #134083 2nd Aug 2012 2:26pm
