![]() | Home > Technical (L322) > I need a new remote shell ? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
awclymm Member Since: 09 Jun 2012 Location: Cheshire, UK Posts: 135 ![]() ![]() ![]() |
Why get a new blade? Just swap the one you currently have into the new casing. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
Any Timpsons shop or mobile caravan will cut the blade for you.
On the bay of flees you can also find "reconditioning" kits that replace the rubber. I think they come from Oz when I looked at keys and the likes last. That way you can retain your current key, no blade cutting or other issues |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
The OZ kit is good but is not EOM looking.
Having subsequently taken my original key fob shell to pieces with a view to looking into replacing the rubber buttons only, as a second spare, I found the origonal rubber buttons are fitted into the fob in such a way it is almost impossible to remove them satisfactorily and I would defy anyone to then replace new rubbers in a truly satisfactory manner.
http://t0.gstatic.com/images?q=tbn:ANd9GcQ...UfJwkeCqHw Oh, well, I did this a long time ago with satisfactory result - easy win really. LOL! Just be calm and patient when doing it. it still takes less time than going to the shop to get a blade cut anyway. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 |
You need to alter the new rubber part so it fits nicely.
Hmm, I did think about doing what you describe but came to the conclusion that using a new fob and having the blade cut would achieve a more satisfactory result.
