Home > Maintenance & Mods (L322) > Fitting Front mudflaps on 08MY
warren1712
England 2019 Range Rover 2.0 PHEV Corris Grey
could anyone point me in the right direction for instructions on how to fit front mud flaps on 08my including removing small panel behind front wheels. The land rover instructions are a little short on verbal explanation Exclamation
Post #13393 18th Feb 2010 11:31pm
Vogue
not what you want to hear, but I looked at this and decided against it when I found you had to drill the body pannels Shocked
Post #13398 19th Feb 2010 10:57am
removing that small lower panel is easy.
Take a look at the side vent instructions for how to remove.
http://www.fullfatrr.com/forum/topic1069.html Discovery 4 HSE
Post #13405 19th Feb 2010 2:22pm
warren1712
Thanks for that it looks easy to do, I will have a go at fitting this weekend Embarassed 2021 L405 Westminster P400e
Post #13411 19th Feb 2010 2:54pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
After finally managing to fit the rear mudflaps on mine, I managed to gently lever out the bottom part of the small panel as per the earlier photo. However, the top seemed to be still firmly attached to something and it was getting dark - so I decided it was safer to ask on here than get the spade out for more leverage ...
The LR fitting instructions just indicate the a pull is required - is this true ?
Post #14875 15th Mar 2010 1:52pm
warren1712
I took the easy option and negotiated a price with the local stealer Sad
After receiving the car back I used it for a week;then at the weekend washed the car and found that they had not aligned the two front panels correctly causing the front doors to rub on the front panels. Big Cry
Back in today for installing correctly and paint Embarassed 2021 L405 Westminster P400e
Post #14876 15th Mar 2010 2:00pm
Steve R
United Kingdom 2004 Range Rover Vogue 4.4 V8 Stornoway Grey
From memory mine had a single bolt clamping the top edge of the lower panel to the wing - located in the top front corner of the lower panel.
You can just about get to it when you pull the wheel arch liner out of the way. You just need to undo it a bit to release the panel as it's slotted.
This was on my '04 RR, I'm guessing this hasn't changed on later models...
Steve.
Post #14886 15th Mar 2010 3:22pm
VaguelyVogue
Ah so !
The half undone bolt on RRUK's photo at the bottom of the fins - that makes sense now - thanks !
Post #14892 15th Mar 2010 6:31pm
The panels just pull off - fitted front mudguards last week.
The bolt is for the vent/Gills......
Post #14893 15th Mar 2010 6:50pm
Steve R
No, I meant the other bolt in RRUK's photos, the one in front of the grills on the front wing. This needed loosening on mine before the lower panels would come free...
Post #14895 15th Mar 2010 7:07pm
OK I guess the owner tightened the bolt over the panel clip.
THey pull off - see below:
Post #14896 15th Mar 2010 7:18pm
Steve R
Good point - probably over-tightened by a previous owner when the side steps were fitted to mine.
I re-tightened them when I finished fitting my mudflaps recently... Embarassed I wondered why it wasn't in the
instructions. Laughing
Post #14898 15th Mar 2010 7:38pm
VaguelyVogue
I think that I have the same problem - mine definately don't pull off (the lower two catches lever off with a large screwdriver) - although they might lever off using a garden spade. However, I'm going to try undoing the bolt before resorting to the spade !
Post #14919 16th Mar 2010 9:52am
Vogue
I had to loosen a bolt on mine at the top of the panel, think it was 10mm, I accessed it by pulling back the wheel arch liner immediately next to the panel. Bit of a struggle but brute force won out without damage.
Post #14920 16th Mar 2010 10:49am
