![]() | Home > Maintenance & Mods (L322) > Fitting Front mudflaps on 08MY |
warren1712 Member Since: 18 Feb 2010 Location: Across from the Trout Lake Posts: 35 ![]() ![]() ![]() |
could anyone point me in the right direction for instructions on how to fit front mud flaps on 08my including removing small panel behind front wheels. The land rover instructions are a little short on verbal explanation |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
removing that small lower panel is easy.
Thanks for that it looks easy to do, I will have a go at fitting this weekend |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
After finally managing to fit the rear mudflaps on mine, I managed to gently lever out the bottom part of the small panel as per the earlier photo. However, the top seemed to be still firmly attached to something and it was getting dark - so I decided it was safer to ask on here than get the spade out for more leverage ...
I took the easy option and negotiated a price with the local stealer |
Steve R Member Since: 02 Mar 2010 Location: Warwickshire Posts: 53 ![]() ![]() ![]() |
From memory mine had a single bolt clamping the top edge of the lower panel to the wing - located in the top front corner of the lower panel.
Ah so !
The panels just pull off - fitted front mudguards last week.
No, I meant the other bolt in RRUK's photos, the one in front of the grills on the front wing. This needed loosening on mine before the lower panels would come free... |
OK I guess the owner tightened the bolt over the panel clip. THey pull off - see below:
Good point - probably over-tightened by a previous owner when the side steps were fitted to mine.
I think that I have the same problem - mine definately don't pull off (the lower two catches lever off with a large screwdriver) - although they might lever off using a garden spade. However, I'm going to try undoing the bolt before resorting to the spade ! |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3806 ![]() ![]() |
I had to loosen a bolt on mine at the top of the panel, think it was 10mm, I accessed it by pulling back the wheel arch liner immediately next to the panel. Bit of a struggle but brute force won out without damage. |
