![]() | Home > Technical (L322) > Engine system fault |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
the battery is a good place to start, also maybe the fuel pump if you had quarter or less in the tank... ... - .- -.
paul r Member Since: 27 Feb 2012 Location: Nantwich Posts: 217 ![]() |
The fuel guage was inbetween 1/4 and 1/2 full. Battery seems fine though?
smartymarti Member Since: 01 Aug 2012 Location: Durham Posts: 32 ![]() ![]() ![]() |
have you had a chance to scann to see if theres a fault code left behind theat might help |
I havent got a fault code reader unfortunately......how much are they and where from?
search "RAC" or "IIDTool" ... - .- -.
Even a bobby basic one for £20 of flee bay with give you the fault code then look it up, if not I'm sure some one local will scan it in for you |
Ukdave104 Member Since: 26 Apr 2012 Location: Aberdeen Posts: 116 ![]() ![]() ![]() |
Thinking of getting one of these tools. Looking at a "Pro-scan" unit on flea bay. Anyone ever used one of these and if they are any good |
fyi, the cheapy ones can read faults but cannot clear them.... ... - .- -.
Abstract below taken from the add. Would post a link but can't seem to do it on the i-pad |
these codes read by generic scanners are only the basic ones, which by law all car manufactres have to make accessible...the suspension ,hdvc etc codes are landrover specific codes and can only be read/cleared by dedicated obd scanners like the IIDTool ... ... - .- -.
All seems to be fine now. not had even a blip and done a few hundred miles since this happened. Couldnt have been some dodgy fuel from the supermarket or something could it?
