Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 7 of 49 <123 ... 678 ... 474849>
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Offroad display ... thing that shows you wheel position etc, also the only way on touch screen to see easily the 'mode' as motorway has no indicator. Check the 'MANUAL' and it will show the mode in their screenshot. It does not occur, EVER. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #133818 31st Jul 2012 9:10pm
T24RES
With you now Thumbs Up
Post #133828 31st Jul 2012 9:33pm
T24RES wrote:
PaulB wrote:
I will need to check, but i think my motorway lowering activates at around 65mph.
The later facelifted FF drop at 100mph which is next to useless, oh and the rear wiper stays on if activated instead of delayed sweep. Shocked
If you turn on the rear wiper then imediately off again, then wait the desired amount of time, then switch on and it will work at that delay period...
ie, switch on-off-on and the rear wiper will run constantly
switch on-off-wait 10secs-on wiper will run with a ten second delayed sweep
and so on...
Craig Thumbs Up
Post #133854 1st Aug 2012 12:40am
T24RES
This is what i am talking about. It doesn't say that the control indicates a drop in height just that it does it. I would like to adjust the speed that it activates the m/way height to say 65mph
Post #133945 1st Aug 2012 3:22pm
stu
my last FFRR 2005 MY used to display the suspension lowering at motorway speed, i made a point of trying it on a couple of occassions... Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #134408 5th Aug 2012 8:29am
06 onwards FF's dont lower at speed... Simples Rolling Eyes
Craig Thumbs Up
Post #134423 5th Aug 2012 9:27am
stu
where did you get this info from Craig? my face lift 2005 model lowered and my current TDV8 does it as well.
just curious to know if mine is different from other peoples??
earlier cars used to lower at a sensible motorway sort of speed, the newer ones are set at 100mph for some crazy reason. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #134429 5th Aug 2012 10:12am
Stu, as far as im aware when the Facelift happened that function was removed hence the light disappearing from the dash... Pre facelift cars lower at 65mph
Craig Thumbs Up
Post #134533 5th Aug 2012 9:09pm
stu
Craig..i've never had a light on my dash, was that in the pre facelift models?
on my 2005 if you go to the suspension display on the touch screen, when you pass the magic speed... Twisted Evil the display changes to lowering and drops the car by how ever many mm it was.
only saying what my cars do. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #134535 5th Aug 2012 9:19pm
Pre facelift cars have an extra light with a motorway sign. The light that states your car is in "normal height" would go out and the motorway light (your operating light on the left) would come on when the car had lowered itself 25mm... You could also lock it in motorway mode on pre facelift cars...
Craig Thumbs Up
Post #134537 5th Aug 2012 9:27pm
stu
ok..well i've learnt two things today then!! the lights on the display and how to adjust my rear wiper.
Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #134539 5th Aug 2012 9:31pm
Monky
United Kingdom 2008 Range Rover Vogue TDV8 Buckingham Blue
I want!
I have a 2008 TDV8 Vogue with a 2010 front/rear conversion.
If I buy the IIDTool for my 2008 will it have the menu option for DRL's as I have the later LED headlights? Want to turn this feature on but unsure if it's going to work and don't want to fork out if it wont.
Also how much are these from Britpart as well?
Thanks,
T RR Vogue 2008 w/ 2010 Conversion
Post #134809 7th Aug 2012 7:32pm
The DRL setttings on the IIDTool will bring on the main beam bulbs at varying %age on your original headlights.
Maybe Steve or Patrick from Gap can confirm what difference the LED headlights will make.
No idea what the current price is.
Cheers! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #134810 7th Aug 2012 7:38pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Don't see why it would not do it. On my 2005 with IID tool it can be set for main beams (% variable) and also headlights. The wiring to the new lights would just control the same things as the old one, the only difference is the LED sidelights, but they take the control form the sidelights on the older lights so as long as you have resistors it should not make a difference.
I got mine from LR parts worked out at about £231 + VAT Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #134814 7th Aug 2012 8:04pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Be warned that if you use main beams at 60% in Yorkshire you get a lot of people pulling behind you and flashing their main beams trying to tell you that you're main beams are on. This is obviously solved by letting them overtake and then turning your main beams on properly, optionally (and depending on how agressive they have been) follow them with your main beams on for 20 miles or so Thumbs Up
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #134880 8th Aug 2012 9:31am
