Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 9 of 49 <123 ... 8910 ... 474849>
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
SteveMFr wrote:
Your BCM is still more or less BMW... Laughing
Get cracking on the auto-unlock then! Twisted Evil Laughing
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #135108 9th Aug 2012 4:25pm
Think i might see about buying one of these things since everyone raves about them , but knowing my luck i'll end up Censored things up … Laughing Laughing
Post #135129 9th Aug 2012 6:23pm
Make sure you buy one for the 2002-2005 model Mick Whistle
Post #135134 9th Aug 2012 6:32pm
SteveMFr
Site Sponsor
'nuther coupla weeks for the 2010+, Mick.
Glad to have you on board then, tho. Threads will become even livelier. Shocked
Laughing
JK. And if anything goes wrong - we're here to help. Cool
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #135220 9th Aug 2012 10:47pm
Don't do it Steve, he'll make yours and Patricks' lives hell!! Rolling with laughter Got - 2017 SDV8 Autobiography in Loire Blue
Post #135223 9th Aug 2012 10:52pm
Now now Al , I'll have you know I resemble that remark Laughing Laughing Anyhow maybe getting one means I can post elsewhere other the Off Topic section Laughing Laughing ......
Post #135255 10th Aug 2012 4:14am
ahebron
New Zealand
Any one else had 'Safe Mode Active' flash up when using IID Gap Tool then DS2 Count and ISO Count?
mine did this last night and I have no idea what they mean.
Adrian VW Amarok 2014 Highline auto
Post #135708 13th Aug 2012 10:16am
SteveMFr
Site Sponsor
Hi Adrian,
Chatted with Christian to make sure nothing was missed.
Safe Mode Active appears when communication to Engine Control module can't be established.
When this occurs, the menu is slower because the cruise control button state is obtained via an alternative (slower) method.
Two reasons this to occurs ;
1- Key is in accessory instead of ignition. The menu can be called up but engine and some other ecu's are not awake.
2- bad connection on ISO bus (PIN 7 of OBD connector).
ISO and DS2 count can be used to debug the problem.
HTH
Steve
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #135810 14th Aug 2012 7:39am
ahebron
New Zealand
Thanks Steve.
Post #135823 14th Aug 2012 9:32am
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
How to reset air suspension
Ok this might be a stupid question, but instead of disconnecting the battery, how do I reset the suspension with the iid tool?
To date I have been selecting "re enable eas". Is this correct?
Post #136598 17th Aug 2012 10:04pm
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
A couple of questions.
Will the IDD tool allow me to enable auto-locking?
Also can I turn on the feature that leaves the headlights on for a few seconds after I turn off the ignition.
Finally can I use the tool to find out which parking sensor is not working?
Thanks!
Post #136606 17th Aug 2012 11:09pm
for auto-locking,
BPM-BODY PROCESSOR.
Lazy unlock from door key
Lazy lock from door key
Lazy unlock from remote handset
Lazy lock from remote handset
Arming acknowledgement with horn/siren
Disarming acknowledgement with horn/siren
Panic Alarm
Automatic Relock after 2 min
Speed Related Locking Repeat
Driver window one-touch close
headlights on, few options,
LCM-LIGHT CONTROL
Daytime Running Light ( High Beam, Main Beam or None )
Follow me home with reverse lamp
FMH Front fog lamps
FMH Front position lamps
FMH High beam headlamps
FMH License plate light
FMH Low beam headlights
FMH Rear position lamps
FMH Reverse lamp (LCM Coding Index 11 only)
FMH Style
Follow Me Home ( FMH ) cancel with lighting switch
Front fog lights off if main beam on
parking sensors,
listen to each sensor, if it doesnt make a clicking sound then its faulty... ... - .- -.
Post #136710 18th Aug 2012 9:21pm
Stryke
Thanks for that Stan.
Good man Thumbs Up
Post #136711 18th Aug 2012 9:39pm
Aurrian
2005 Range Rover Vogue SE Td6 Java Black
If there is an error on your parking sensors the IID tool should interpret the code and tell you which sensor caused the error.
The other way is to switch on the parking sensors then lightly touch the sensors with one finger and listen for the clicking sound. The "dead" one will not click Thumbs Up
Post #136835 20th Aug 2012 12:44am
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Is there anything the IID Tool can do to the "sensitivity" of the Auto Headlights? Mine don't seem to come on until way after all other roadusers have "lit-up", and are still on long after I've donned my sunglasses!
Post #136856 20th Aug 2012 10:06am
