Home > Maintenance & Mods (L322) > Air leaking from air suspension
hoffman
2005 Range Rover Vogue Td6 Orkney Grey
(2005 Vogue TD6)
Car hisses when driving along bumpy road. Hissing is constant when vehicle fully elevated. Air coming out as shown (front n/s):
Anyone else had experience of this? Can it be fixed?
If not, I think this (click here) looks like the right part. Am I right? Is this easy to replace or a job for the garage?
Any assistance appreciated!
Tim
Post #135623 12th Aug 2012 5:14pm
Not known about air from there (sounds like it is Censored ), but here is how to replace strut:
http://www.fullfatrr.com/gallery/thumbnails.php?album=359
And that is a good price from Paddock. Island 4x4 used to be best but they are at £219 + VAT now .
Post #135637 12th Aug 2012 6:41pm
Are you sure it's not coming from the airbag?
Post #135641 12th Aug 2012 7:26pm
Brian GOG
United Kingdom 2002 Range Rover HSE Td6 Epsom Green
You'll probably find that the rubber is worn through around the back where you can't see. It's not a bad job to do. Make sure you have a second pairs of hands with you when you do it. Once you've lowered the strut down you can get to the pipe connector ok. Only other thing I can think of is that we have a had a few where the bolts through the hub carrer have been siezed so try to undo these first! Happy fixing!!
Post #135659 12th Aug 2012 9:55pm
hoffman
Many thank for the help. I will check the leak again.
Almost inspired to have a go, thought the instructions (link above) were great - not sure my toolbox is adequate though! Any really good engineers in Hampshire (New Forest) want to do it?
The instructions for replacing the strut showed both being replaced. Do you have to replace both at the same time? I was not planning to do that.
Thanks again...
Post #135677 13th Aug 2012 12:17am
Brian GOG
Can't help on the fitting side I'm afraid. The strut assembly is also the shocker which are always recommended to be fitted as a pair, but that's also in an ideal world. I always offer our customer both options more so for the legal side but generally it's only the leaking one that gets done there and then. It might be worth checking the other once you are all back up and running.
Post #135678 13th Aug 2012 12:23am
ALWAYS recommended to replace shock absorbers and springs in pairs. You'll kick yourself if you do only one then the other goes 5000 miles later in any case.
Regarding tools, a good socket set, some spanners and a breaker bar with extension if needed should do you, and a good jack and axle stands. Oh, you may need a reset and calibration tool (IID/RAC etc)
Don't know of anyone specific (e.g. RR indie) in the Forest, but depending on where you are I may be able to recommend a good garage. (expat New Forester !)
Best I can do is
4x4servicingdorset.co.uk
or
EUROTEAM SERVICES LTD ( I drive by this place once a week, always busy, always lots of Landy's)
197, BURLEY ROAD, BRANSGORE
BH23 8DF CHRISTCHURCH, DORSET
Phone: +44 (0) 1425 674240
Fax: +44 (0) 1843 822 871
or
http://www.paullightlandrovers.co.uk/
or up this way a bit
Keith Gott Landrover Specialists,
Greenwood Farm,
Old Odiham Road,
Alton,
Hampshire
GU34 4BW
ENGLAND
Sales
Telephone +44 (0)1420 544330
Fax +44 (0)1420 544331
Email sales@keithgott.co.uk
Service
Telephone +44 (0)1420 544333
Fax +44 (0)1420 544332
Email service@keithgott.co.uk
or
Chris Bush at Cross axle services in Upper Wield 01420 565939 .
Post #135679 13th Aug 2012 1:00am
Budgie
There's also Brooklyn 4x4 at Nursling, off the M271. Wink
Post #135682 13th Aug 2012 2:54am
hoffman
Wow, thanks for the prompt response.
47p2 was right, I got the source of the leak wrong! The air was blasting down from the airbag above, thus:
I should check these things more carefully! You can actually put your finger on the hole and if you press hard enough stop the air hissing out.
I will check a few of the garages out.
Thanks
Tim
Post #135688 13th Aug 2012 9:00am
Going to be difficult driving along like that Laughing .
Post #135714 13th Aug 2012 10:34am
Ha ha Joe, reminds me of Hans Brinker, the boy who stuck his finger in a dyke Laughing Laughing
Do they still tell that story at school, if so I wonder if they have changed the wording.
I can just imaging little Mick coming home from school and mummy saying "what did you learn today Mick"?
"Oh we learned about little boys sticking their fingers in dykes" Embarassed
Post #135717 13th Aug 2012 10:49am
