Home > Maintenance & Mods (L322) > Air leaking from air suspension |
hoffman Member Since: 12 Aug 2012 Location: Southampton Posts: 3 |
(2005 Vogue TD6)
12th Aug 2012 5:14pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
Not known about air from there (sounds like it is ), but here is how to replace strut:
12th Aug 2012 6:41pm |
Are you sure it's not coming from the airbag? |
12th Aug 2012 7:26pm |
Many thank for the help. I will check the leak again.
13th Aug 2012 12:17am |
Brian GOG Member Since: 08 Dec 2011 Location: leeds Posts: 57 |
Can't help on the fitting side I'm afraid. The strut assembly is also the shocker which are always recommended to be fitted as a pair, but that's also in an ideal world. I always offer our customer both options more so for the legal side but generally it's only the leaking one that gets done there and then. It might be worth checking the other once you are all back up and running. |
13th Aug 2012 12:23am |
ALWAYS recommended to replace shock absorbers and springs in pairs. You'll kick yourself if you do only one then the other goes 5000 miles later in any case.
13th Aug 2012 1:00am |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
There's also Brooklyn 4x4 at Nursling, off the M271. |
13th Aug 2012 2:54am |
Wow, thanks for the prompt response.
13th Aug 2012 9:00am |
Going to be difficult driving along like that . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
13th Aug 2012 10:34am |
Ha ha Joe, reminds me of Hans Brinker, the boy who stuck his finger in a dyke
13th Aug 2012 10:49am |
