![]() | Home > Maintenance & Mods (L322) > Visit to gearbox specialist this week, any questions? |
| Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1530
Great news Craig. Any comment about the 6 speed?
Cheers!
| bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055
Interesting, the one which failed on my car must have been the exception then, it never had a tow bar! 2012 SDV8 Vogue SE |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Oh here we go again!!! |
Funny reaction to an innocent observation? |
Really! Hmmm...
| ikilla2 Member Since: 22 Jul 2012 Location: England Posts: 72
Craig, who is gearbox specialist? |
| dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244
im still on the fence about getting mine done im on 100k now and the gearbox seem fine
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
Seems nobody asked the most pertinent question then.
Is this on the 5 or 6 speed box please? Craig |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
There was/is a problem with some Mercedes and glyco contamination, from memory the main cause was Valeo radiators and coolers leaking causing cross contamination. Never heard of a FFRR having this problem though |
Both I believe Craig. Basically, any car which has the transmission fluid cooler in the main radiator will be susceptible to this. Radiators have a finite life and when they do let go quite a lot do so between the water and oil parts. Quite a common pre-emptive thing is to fit an ali rad, or a separate gearbox oil cooler.
Have personally seen 4 now. EDIT. From memory, all were either 56 plate or 07 which would make them 6 speeds. |
Correct me if im wrong but my gearbox cooler is separate to the water rad im sure...
They rebuild all my customers gearboxes... Just did my TD5 pickup... Craig |
